MS VAR (Krolzig wbc_multivariate_pt1.RPF)
renis
Unread post by renis »
Dear Tom Doan,
For educational purposes, I have been trying to run the above code which refers to the source code msvarsetup.src. In general, it works fine; however, when I get down to the line
set smoothp1 gstart gend = pstar=%MSVARMarginal(msvarptsm(t),0),pstar(1)
I get the following message
## SX11. Identifier MSVARPTSM is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>>Marginal(msvarptsm(<<<<
Can you help me to get around this problem. My RATS version is 8.00. Many thanks indeed.
Kind regards.
Re: MS VAR (Krolzig wbc_multivariate_pt1.RPF)
You need an updated MSVARSETUP.SRC file along with the newer MSSETUP procedures.
