Errors in Repilicating Mountford and Uhlig 2009
dnfloro1
Unread post by dnfloro1 »
Hi Tom!!!
I'm replicating Mountford and Uhlig (2009)(MU) by adding an oil shock to the system. Need your kind help in figuring out the error in my codes in the attached.
I am running the MU without delay shocks, but I am getting the error:
The Error Occurred At Location 851, Line 52 of FORCEDFACTOR
Called From Location 514, Line 32 of loop/block
What could be wrong?
best regards
dnfloro1
scotlandata_99.xls
data
(28.5 KiB) Downloaded 648 times
mujaesetupscot.SRC
source file
(1.54 KiB) Downloaded 941 times
mub1_practice.RPF
MU (2009) codes
(5.38 KiB) Downloaded 990 times
Re: Errors in Repilicating Mountford and Uhlig 2009
You shouldn't put the NOPRINT option on the ESTIMATE until you know it's right. For some reason your RBPEXP and GVA series are identical, so the covariance matrix is deficient rank.
Locked
