I ran this GMM :
@ablags(collapse) policy abpolicy
instruments abpolicy dgrowth{2 3 4} dinaxindep1{1 2 3} dinaxfsi{2 3 4} dinaxopen1{1 2 4} dinaxfiscal3{1 2 3}
inquire(reglist,valid=absample)
#dpolicy{2} dgrowth{2 3 4} dinaxfsi{2 3 4} dinaxopen1{1 2 3} dinaxindep1{1 2 3} dinaxfiscal3{1 2 3}
mcov(instruments,lwform=||-1.0,2.0,-1.0||,smpl=absample)
linreg(inst,wmatrix=inv(%cmom),robusterrors,lwindow=panel,$
title="Arellano-Bond One-Step Estimator") policy
#policy{1} growth{1} inaxfsi11 inaxindep1 inaxfiscal3 inaxopen1
ad got this result:
Linear Regression - Estimation by Arellano-Bond One-Step Estimator
With Clustered Standard Error Calculations
Dependent Variable POLICY
Panel(64) of Quarterly Data From 1//1995:01 To 17//2009:04
Usable Observations 847
Degrees of Freedom 841
Skipped/Missing (from 1084) 237
Mean of Dependent Variable 6.4300826446
Std Error of Dependent Variable 5.5887466183
Standard Error of Estimate 1.7179282662
Sum of Squared Residuals 2482.0244008
J-Specification(72) 15.0000
Significance Level of J 1.0000000
Durbin-Watson Statistic 2.2188
1. POLICY{1} 0.923736969 0.041418843 22.30234 0.00000000
2. GROWTH{1} -0.004858936 0.028863025 -0.16834 0.86631214
3. INAXFSI11 -0.012578940 0.005864544 -2.14491 0.03195977
4. INAXINDEP1 0.082452108 0.114935138 0.71738 0.47313999
5. INAXFISCAL3 -3.064695178 1.228778249 -2.49410 0.01262772
6. INAXOPEN1 0.336338456 0.084003334 4.00387 0.00006231
No matter how I vary the instruments, I alwasy get a J-Specification of 15.00000 and a p-value of 1.000
What could be wrong???????????
I's appreciate any guidance on this
regards
dnfloro1
P-Value of J-Stat is always 1.000?!!
Re: P-Value of J-Stat is always 1.000?!!
You would need to post the program and data set. That doesn't happen with other data.
