GARCH-M and rolling
victor
GARCH-M and rolling
Unread post by victor »
I am using code for rolling regression for GARCH given in user manual to estimate GARCH-M. Please see if I have done everything in correct way. I am getting the outputs and graphs. I have done following things:
I have added %garchv to make it GARCH-M
I have changed coeff (2) to (3), (3) to (4), and (4) to (5)
Also, at the end I want to collect estimation of GARCH-V and window date in each estimation in two columns. How can I do that?
Victor
0000000000000
CALENDAR(M) 1997:07
DATA(FORMAT=XLS,ORG=COLUMNS) 1997:07 2012:07 STK
table
compute width=50
dec vect[series] coeffs(5)
clear coeffs
do gend=width,180
if gend==width
garch(p=1,q=1,regressors) gend-width+1 gend STK
#constant %garchv
else
garch(p=1,q=1,initial=%beta,hessian=%xx,regressors) $
#constant %garchv
compute %pt(coeffs,gend,%beta)
end do gend
spgraph(vfields=3,samesize,$
footer="Rolling GARCH Estimates, Window Width = 50")
set lrstd = sqrt(coeffs(3)/(1-coeffs(4)-coeffs(5)))
graph(hlabel="Estimated Process Standard Deviation",min=0.0)
# lrstd width *
graph(hlabel="Lagged Variance Coefficient")
# coeffs(5) width *
graph(hlabel="Lagged Squared Residuals Coefficient")
# coeffs(4) width *
Re: GARCH-M and rolling
That looks correct. Wouldn't
print / coeffs(2)
give you what you want for the GARCH-V coefficients?
victor
That works. Thanks
victor
Problem 1 - I am also running a very big data program similar to above (on Rats 8.2ver). How can I collect coeff (2), convergence result(1/0.1), and Significance for coeff (2) in three columns.
Problem 2 - When I run same code on Rats 8.3 version I get absolutely different results, many zeros, no convergence, different values...What I am missing?
What is your data series? Have you tried running a full sample GARCH with diagnostic tests?
victor
May be my question was no precise, for the code given above and data set attached I am getting very different result for Rats ver 8.2 and ver 8.3. Am I missing some sort of patch etc.? When I run simple garch-m (no rolling) both versions (8.2 and 8.3) converge giving same result.
For the same code and data attached I also need to collect coeff (2), convergence result(1/0.1), and Significance for coeff (2) in three columns side by side. This is because I plan to run even a bigger data set in future.
Data.xls
(35.5 KiB) Downloaded 775 times
You're trying to fit a rolling GARCH model with very short windows to data which don't really show much of a GARCH effect. This is the result of a test for ARCH on the first 50 data points:
Test for ARCH in STK
Using data from 1997:07 to 2001:08
Lags Statistic Signif. Level
4 0.439 0.77996
As it says in the User's Guide, the estimates will get quite unstable if you hit an outlier after a quiet period. Different versions of RATS use different guess values, but neither one is going to give a set of sensible results if asked to fit a model that doesn't work.
victor
print / coeffs(2) %CONVERGED (2) %TSTATS(2)
I am getting error when I run above command.
How can I collect coeff (2), convergence result(1/0.1), and Significance for coeff (2) in three columns side by side?
%CONVERGED is a scalar (for the entire model, not coefficient by coefficient) and you're not saving it anywhere. You would need to do something like this:
add
clear(zeros) convhist
before the loop
then
compute convhist(gend)=%converged
after the GARCH inside the loop. You can then print out the convhist series.
Given how few data points you have in the segments, you're probably better off using the full sample GARCH estimates as your guess values.
garch(p=1,q=1,regressors) / stk
compute beta0=%beta,xx0=%xx
do gend=width,180
   garch(p=1,q=1,regressors,initial=beta0,hessian=xx0) gend-width+1 gend stk
   # constant %garchv
end do gend
There's no guarantee that that will work, but at least you won't be feeding forward unconverged estimates.
