differences in variable(i)
Aaron
Post by Aaron »
Dear All,
I am writing a code to estimate a threshold cointegration model.
In the below code, "thresh_test(i)" creates an error. If just a series from the attached data set used, for example r_10, the program works.
What is the problem? How can I resolve this issue?
Thank you very much. :D
cal(m) 1955
all 1998:12
open data tres_coint_o.xls
data(format=xls,org=obs)
linreg r_short 1964:01 1998:12 mu; # constant r_10
dif mu / dmu
compute low = fix(%nobs*.15) , high = fix(%nobs*.85)
set thresh_test = mu
order thresh_test
compute thresh = thresh_test(low)
compute rss_test = 1000000.0
do i = low,high
   set yy      = mu - thresh_test(i)
   set flag    = %if(yy{1}<0,0,1)
   set minus   = 1 - flag
   set z_plus  = flag*yy{1}
   set z_minus = minus*yy{1}
   lin(noprint) dmu
   # z_plus z_minus; * use the selected lag
   if %rss < rss_test {
      compute rss_test = %rss
      compute thresh = thresh_test(i)
end do I
dis ' Threshold = ' thresh
Aaron
tres_coint_o.xls
(52.5 KiB) Downloaded 785 times
Re: differences in variable(i)
Post by TomDoan »
You might want to look at Enders-Siklos since that's what you're doing.
The problem that you're running into is that you're running the regression well into the data set so <<low>> and <<high>> aren't correct. Change them to:
compute low = %regstart()+fix(%nobs*.15) , high = %regstart()+fix(%nobs*.85)
which will relocate them into the actual data range.
Aaron
Post by Aaron »
Thank you very much for your help. I am also looking at the procedure.
Sincerely,
Aaron
