read data from not first entry .Rats can't do it right
lizhengeconomic
Unread post by lizhengeconomic »
open data txch.xls
data(format=xls,org=columns,left=2) 4 3065 date eurusd yenusd $
  gbpusd r_eurusd r_yenusd r_gbpusd
Though the entry is 4 3065,but the data in Rats is 1 3062, you can look at the excel file.
read data.RPF
(122 Bytes) Downloaded 798 times
txch.xls
(451.04 KiB) Downloaded 833 times
Re: read data from not first entry .Rats can't do it right
It's doing exactly what it's supposed to do. From Page Int-116 in the RATS v8 "Introduction to RATS":
Whether you can select specific observations out of the file depends in part on whether
or not the file includes a date column:
• If there is no date column or row on the file, RATS assumes the first observation on
the file corresponds to the first observation you request on DATA. You can ask only
for entries at the beginning of the file, never a block in the middle or end. If you
need to be able to read in a subset of the data, you could first convert the file to
rats format.
• If there are dates on the file, and the frequency on the file matches the current
CALENDAR seasonal, DATA will locate the entries requested and fill in any skipped
dates with missing values.
• If the frequency of the current CALENDAR does not match the frequency of the data
on the file, RATS will compact or expand the data as it reads it in. See Section 2.4.
• If you don’t use a CALENDAR instruction, RATS will read observations from the
beginning of the file. Any dates on the file are ignored.
What's the point of not reading entries 1 to 3?
lizhengeconomic
TomDoan wrote:It's doing exactly what it's supposed to do. From Page Int-116 in the RATS v8 "Introduction to RATS":
rats format.
thank you, TomDoan! I know your meaning ,thanks.
