Time-varying transition probabilities in MS VAR
renis
Unread post by renis »
I have been trying to estimate a three-regime MS-VAR (and regime-dependent impulse-response functions) with time-varying transition probabilities. The time-varying regime probabilities are a function of macroeconomic variables. I am wondering whether time-varying transition probabilities are feasible in the code (eev_mcmc.rpf) that follows the Ehrmann-Ellison-Valla(2003) approach and that uses mssysregression.src source file. If so, how those macroeconomic variables can be input and how the code can be modified?
Many thanks indeed.
Kind regards.
Re: Time-varying transition probabilities in MS VAR
1. Do you have a reference for that? Gibbs sampling for time-varying transition probabilities would require sampling a multinomial logit.
2. Is there a reason that you want to estimate such a complicated model? Did you successfully estimate a three regime model without time-varying transitions?
