Rolling VAR-GARCH
jimdimit
Rolling VAR-GARCH
Unread post by jimdimit »
Dear All,
I have set up the following rolling VAR-BEKK GARCH. I want to use the first 600 return data to make some forecasts from observation 601 to 901. Although it runs fine, I am not sure if it restricts my sample to where I want to in every loop. Thank you for your time and help.
*Loading Data
allocate 1000
open data C:\data\stocks.txt
data(format=free, org=col) / sp500 ftse100
source mvgarchfore.src
*return series
set rsp500 1 1000 = log(sp500)
set rftse100 1 1000 = log(ftse100)
dif rsp500 2 1000 drsp500
dif rftse100 2 1000 drftse100
compute ss = 599
*Loop
do time = 1,300
*VAR
system(model=var)
variables drsp500 drftse100
lags 1 1
estimate(noprint, residuals=resvar) time time+ss
*GARCH
garch(noprint,robusterrors,p=1,q=1,mv=bek,variances=spillover,pmethod=simplex,hmatrices=hh,rvectors=rd) / resvar(1) resvar(2)
*SETTING SOME SERIES
set std1 1 time+ss = hh(t)(1,1)
set std2 1 time+ss = hh(t)(2,2)
set z1 1 time+ss = rd(t) (1)
set z2 1 time+ss = rd(t) (2)
compute xx = z1(time+ss)
@MVGarchFore(steps=1) hh rd
set hfor time time = hh(time+ss+1)(2,2)
set dhh2 time time = hfor(time)-std2(time+ss)
end do
Re: Rolling VAR-GARCH
You should never run something like this with "NOPRINT" options until you're sure you have everything correct. Start with a smaller range to test it.
There are several rather clear problems with this. For instance, your earliest start period is "1", but you can't run the VAR starting at entry 1 because of the lags. You're also not running a VAR-GARCH, but a VAR with a GARCH on the residuals. You can do a GARCH that does both simultaneously by using the MODEL option. You need to use the MV=BEKK option on @MVGARCHFORE if you did a MV=BEKK on the GARCH instruction.
jimdimit
Tom thank you for very much your helpful comments,
Return series start from 2 and end to 1000
so the inputs for the VAR(1,1) should start from 3 (i.e. time+2) (since I lose one observation from the lag) and end at the end of the subsample (time+ss)
I think that if I use the garch command with the model option I have to specify a sample or it will use all the available sample (if I don't specify a sample, all GARCH estimations in the loop have identical estimation outputs)
I have modified the code accordingly as follows:
*Loading Data
allocate 1000
*return series
compute ss = 599
*Loop
do time = 1,300
*VAR
system(model=var)
lags 1 1
estimate time+2 time+ss
*GARCH
garch(robusterrors,p=1,q=1,mv=bek,variances=spillover,pmethod=simplex,hmatrices=hh,rvectors=rd) time+3 time+ss
@MVGarchFore(MV=BEKK,steps=1) hh rd
end do
I would like to ask, if I just use 1 as start for the VAR when in fact my sample starts from 3, how would rats treat my series? I mean is it different for rats to 'read' Nans instead of specifying for it a sample without the Nans that starts from say the 3-rd observation? or we set a usable sample without Nans so that we don't run into errors in the (garch) estimation?
Because GARCH can't accept missing values inside the sample (since those would break the recursion), you have to be careful not to give it a range that includes NA's.
