Impulse Response Graph
tophukg
Hello everyone,
I have a question about how to get data from .rgf file. I'm not good at writing code, after having a .rgf file, i don't know how to change, add, compare and do something else and if i want to change something such as : the name, i must estimate again. Can you show me the way to output the data or get them from .rgf file ? Thus, i can copy it and do everything i want.
I will appreciate any kind of comment, thanks in advance
Re: Impulse Response Graph
You can't retrieve data from a graph---they've been remapped into pixels. Instead, use @MCPROCESSIRF rather than @MCGRAPHIRF if you want to see the values rather than just graphs.
tophukg
Thanks for your response. I will try
cczzwhy
Hello,Tom!I have a question about how to generate the graph with upper and lower lines in dotted,I failed to save them in black and white,can you help me?
What does "failed to save them in black and white" mean? Did you click on the toolbar icon to switch to B&W before saving. You can also use GRPARM(PATTERNS) before doing graphs to switch the representation of all future graphs to black and white.cczzwhy wrote:Hello,Tom!I have a question about how to generate the graph with upper and lower lines in dotted,I failed to save them in black and white,can you help me?
cczzwhy
Thank you very much ,GRPARM(PATTERNS) works fine!
cczzwhy
Well,the graph showed to be black and white,but after I saved them in wmf,it turned back to colored
