Cannot get structural residuals with @MSSysRegStdResids
renis
Unread post by renis »
Using EEV_MCMC.RPF, I have been trying to calculate the structural residuals with @MSSysRegStdResids. More specifically, I add the following command after the model is estimated (having previously declared sresids as a vector of series): @MSSysRegStdResids gstart gend sresids
However, the program returns en error saying:
The Error Occurred At Location 448, Line 34 of MSSYSREGSTDRESID
However, I am not able to identify the issue based on the above information. Kindly advise me how to correct the program and obtain the residuals.
Many thanks indeed.
Kind regards.
eev_mcmc_help.RPF
(6.77 KiB) Downloaded 987 times
Re: Cannot get structural residuals with @MSSysRegStdResids
The MCMC program isn't the one that you want if you're trying to get standardized residuals since it doesn't produce a single set of coefficients (and hence residuals). Use the maximum likelihood program instead.
