reading RATS output
Nabtheberliner
reading RATS output
Unread post by Nabtheberliner »
Tom,
Actually i have the same pb with cov matrix of residuals from the same example from the TSAY book, i get the following output with RATS:
Covariance\Correlation Matrix of Coefficients
         LDRUK        LDRCA        LDRUS
LDRUK 0.0000283715   0.09259709   0.23138784
LDRCA 0.0000026790 0.0000295021   0.43249284
LDRUS 0.0000073900 0.0000140854 0.0000359526
 2.83715e-005
 2.67895e-006  2.95021e-005
 7.39004e-006  1.40854e-005  3.59526e-005
The reading isn't clear, in the book they obtain directly
    LDRUK        LDRCA        LDRUS
LDRUK 0.283715
LDRCA 0.026790 0.295021
LDRUS 0.073900 0.140854 0.359526
With the RATS output, how am i supposed to know that i have to skip the first four 0 after the dot?
Thanks again Tom.
Nabih
q-gdp-ukcaus.txt
(3.85 KiB) Downloaded 1089 times
Re: reading RATS output
If you multiply the data by 100 (which I would recommend anyway), the variances will be multiplied by 10000, so you will be spot on.
