One-sided Hodrick-Prescott filter
Kraus
Unread post by Kraus »
I am struggeling with the end-point problem of the Hodrick-Prescott filter. Using a strictly one-sided HP filter seems to be a solution. Is there an easy way to implement this in the FILTER instruction? Any other suggestions to deal with the problem?
Thank you.
Re: One-sided Hodrick-Prescott filter
You would use DLM to do the local trend model that underlies the H-P filter and filter rather than smooth.
* The HP filter is a local trend model. The system matrices for this can
* be generated using the procedure LOCALDLM with TYPE=TREND and
* SHOCKS=TREND.
@localdlm(type=trend,shocks=trend,a=ahp,c=chp,f=fhp)
* This is the relative variance of the measurement error to trend rate
* disturbance.
compute lambda = 1600.0
dlm(a=ahp,c=chp,f=fhp,sv=1.0,sw=1.0/lambda,presample=diffuse,$
  type=FILTER,var=concentrate,y=lgdp) / hpstates
Kraus
Thank you. Do I get that right that in your example the equivalent of the one-sided HP filter results is to be found in the first entry of the series hpstates (series of vectors)? What is the second entry? It's non-zero. Thanks again.
Kraus wrote:Thank you. Do I get that right that in your example the equivalent of the one-sided HP filter results is to be found in the first entry of the series hpstates (series of vectors)? What is the second entry? It's non-zero. Thanks again.
Correct. In this setup for the local trend model, the second state is the trend rate (i.e. local estimate of the rate of increase).
luching
Unread post by luching »
Is there is a complete example code that implements the one-sided HP filter?
Take HPFILTER.RPF and change TYPE=SMOOTH to TYPE=FILTER on the DLM instruction. (The FILTER instruction only does the two-sided HP Filter which is why you do the local trend model using DLM).
luching
Thanks Tom
