This pair of procedures (on the file varbootsetup.src since you have to use it first) is used to generate bootstrapped data for a Vector Autoregression using a conventional parametric bootstrap. However, their use isn't limited only to VAR's—you can use them to generate data from almost any linear model.
varbootsetup.src
Detailed Description
VARBOOTSETUP,VARBOOTDRAWS procedures
Last bumped by TomDoan on Tue Jun 13, 2023 7:53 pm.
