Puzzled by string comparisons
mboldin
Unread post by mboldin »
I am having trouble getting %strcmp to evaluate to 1 or TRUE
The goal was to set up if statements that compare a string to a state code
if st .eq. "NJ"
did not work as I expected
So I tried if %strcmp(_) but it always evaluates to 0
I am most puzzled that the following code produces 0's
compute [string] st= "NJ"
compute [string] stnj= "NJ"
display "State : " st  stnj  %strcmp(st,stnj)  %strcmp(%left(st,2),%left(stnj,2)) %strcmp("A","A")  %strcmpnc(st,stnj)  %strcmpnc("A","A")
Re: Puzzled by string comparisons
%strcmp(a,b) returns 0 (not 1) for a match, -1 if a<b (that is, would sort first) lexicographically and +1 if a>b.
compute state="NJ"
disp %strcmp(state,"NC") %strcmp(state,"NJ") %strcmp(state,"NY")
gives
1 0 -1
So far as I can tell, the .eq. or == seems to work.
