@SURGibbsSetup
viking76
@SURGibbsSetup
Unread post by viking76 »
I used successfully the @SURGibbsSetup command for a Near-VAR. Now, I would like to introduce a threshold and estimate the near-VAR for values larger and smaller than zero for a specific variable. Here the code:
set low = IRI<0
set high = IRI=0
sur(outsigma=v,smpl=low) 5
# equation1
# equation2
# equation3
# equation4
# equation5
group varmodel equation1 equation2 equation3 equation4 equation5
@SURGibbsSetup varmodel smpl=low
I think that the way I specified the command (@SURGibbsSetup varmodel smpl=low) is not correct, since, as far as I know, @SURGibbsSetup works only with the options "start" and "end". Could you please suggest a solution to this problem?
Many thanks.
Adrian
Re: @SURGibbsSetup
The only place where the data enter into @SURGibbsSetup is on
cmom start end
# %rlfromtable(table)
You can add the option
option SERIES SMPL
then change the cmom to
cmom(smpl=smpl) start end
You would then execute it with something like:
@SURGibbsSetup(smpl=low,model=...)
viking76
Re: @SURGibbsSetup
Thanks a lot Tom, it works!
Adrian
