rolling Window problem. (Diebold Spillover index)
leewoo
Unread post by leewoo »
hello.
I have a problem calculating spillover index proposed by diebold (2009) and the code is proposed by TomDoan.
I revised the code to estimate VECM. Because my data have a cointegration.
whenever I excute the problem, Rats program shotdown.(I.m rats 8.3 trial version user)
but If I delete
eigen(cvalues=cv) %modelcompanion(ectmodel)
if %cabs(cv(1))>=1.0 {
compute spillreturns(end)=%na
next
the program is excuted.
but I want to Skip any data points where the rolling VECM has an explosive root.
How Can I solve the problem?
I attached the code and data.
please help me.
Thanks regards.
compute nspan=200
set spillreturns rstart+nspan-1 rend = 0.0
do end=rstart+nspan-1,rend
   * Skip any data points where the rolling VAR has an explosive root.
      next
   errors(model=ectmodel,steps=nsteps,factor=gfactor,stderrs=gstderrs,noprint,results=gfevd)
   compute gfevdx=%xt(gfevd,nsteps)
   ewise fromvar(i)=%sum(%xrow(gfevdx,i))-gfevdx(i,i)
   compute net = tovar - fromvar
   compute spillreturns(end)=100.0*%sum(tovar)/%nvar
end do end
graph(footer="Spillover plot. Returns. 60 month window. 12 step horizon")
# spillreturns
oil.xls
(64.5 KiB) Downloaded 712 times
ecm.RPF
(3.48 KiB) Downloaded 993 times
Re: rolling Window problem. (Diebold Spillover index)
%MODELCOMPANION doesn't work with the ECT model. However, you shouldn't have to worry about explosive VAR roots if you're running a VECM because you are forcing the dominant roots to be exactly one rather than allowing them to be a random number near one (sometimes below, sometimes above).
