Matrix of Loadings in VECM-GARCH
klaus86
Unread post by klaus86 »
Dear all,
I would like to estimate a bivariate VECM-BEKK model and then compute the orthogonal vector to the error correction coefficients which I need for the calculation of information shares. However, I run into problems when I try to do this in RATS.
I have done this procedure before in the framework of a standard VECM without GARCH errors:
set logspot = log(spot)
set logfutures = log(futures)
*Restrict cointegrating relationship:
equation(coeffs=||1.0,-1.0||) eqxy
# logfutures logspot
system(model=vecm)
variables logfutures logspot
lags 1 to 3
ect eqxy
estimate
*Compute orthogonal vector to error correction coefficients:
compute alphaperp=%perp(%vecmalpha)
This works fine. However, it does not work when I try to estimate the above model with GARCH errors (in my case a standard BEKK-model) by replacing the command "estimate" with the following instruction:
garch(model=vecm,mv=bekk,hmatrices=h, MVHSERIES=bekkHmatrix, rvectors=r,pmethod=simplex,piters=5,method=bfgs,iters=400)
Apparently the error correction term is somewhat ignored in this estimation as it is not displayed in the output. Consequently, the calculation of the orthogonal vector to %vecmalpha is also ignored. I managed to reformulate the VECM-BEKK so that it includes the error correction term:
set retspot = log(spot)-log(spot{1})
set retfutures = log(futures)-log(futures{1})
set ect = log(futures)-log(spot)
system(model=vecm)
variables retspot retfutures
lags 1 to 3
det constant ect{1}
* Estimate by GARCH-BEKK
Yet when I try to calculate the orthogonal vector to the error correction coefficients, i.e.:
I get the error:
## I1. Expected Instruction - ALP Is Not Recognizable As One
>>>>alphaperp=<<<<
Any suggestions how I can solve this issue?
Thanks a lot.
Re: Matrix of Loadings in VECM-GARCH
%VECMALPHA also only gets defined by ESTIMATE, not by GARCH. As you have this set up, you can fetch the alpha's with
compute vecmco=%modelgetcoeffs(vecm)
compute alpha=tr(%xrow(vecmco,8))
which will be a 2 x 1 vector. You can then do
compute alphaperp=%perp(alpha)
klaus86
Thanks Tom. This works fine.
ad15
Unread post by ad15 »
I am able to fetch alpha's from this code. Please help me
I used the following command
system(model=vecm)
lags 1 to 3
det constant ect{1}
Please help. Thanks.
compute alphaperp=%perm(alpha)
Sorry. What's the question? alpha will have the alpha's. The previous poster needed its "perp" for further calculations, but if you just need the loadings, you already have that.
ad15
Dear Tom.
I am not able to extract alpha. When I am writing the code as
print
I see only one ECT term and VCVs of MGARCH.
I am not getting alpha perpendicular. How to get that. Please help thanks.
Yes, you have. The loadings are in alpha and the perp of that is in alphaperp. If you want to see them, use a DISPLAY instruction---COMPUTE computes, it doesn't show.
