MARKOV - General support routines for Markov switching
This is an updated version of the MARKOV.SRC file, providing general support routines for Markov switching models. This requires version 6.30 or later of RATS.
* These functions are fairly generic Markov Chain/Markov Switching model support
* functions. In all cases, the transition matrix P is represented by an (N-1) x N
* matrix, with the final row omitted, as it just forces the columns to sum to 1.
* This makes it easier to estimate the free parameters. Note, however, that the
* vector of probabilities of the states is the full N vector.
* %MCSTATE(P,PSTAR) returns the updated state probabilities given initial
* probabilities PSTAR and transition matrix P.
* %MCERGODIC(P) returns the ergodic state probabilities for transition
* matrix P.
* %MSUPDATE(F,PSTAR,FPT) returns the updated state probabilities given
* the vector of likelihoods (levels, not logs) of the states in F and the
* prior probabilities of the states in the vector PSTAR. FPT is a REAL returned
* by the function which gives the sum over i of F x PSTAR. If F is a vector of
* likelihoods given the states, FPT will be the overall likelihood for this
* entry.
* @%MSSMOOTH P PT_T PT_T1 PSMOOTH is a procedure which produces the VECT[SERIES]
* PSMOOTH given the coded transition probability matrix P and the SERIES[VECT]
* PT_T and PT_T1, which give the estimated probabilities at t given information
* through t and t-1 respectively.
* %MSSMOOTHCALC(pfull,pt_t,pt1_sm,pt1_t) does the smoothing calculation for one
* time period. pt_t is the estimate of the probabilities for time period t given
* data through t, pt1_t is for time period t+1 given data through t, pt1_sm is for
* time period t+1 given all data, and pfull is the (full) transition matrix for
* states at t to t+1. This is safeguarded against divides by zero when pt1_t has
* underflowed down to a zero value.
* %MSLOGISTICP(theta) returns the result from transforming an N-1 x N matrix of
* logistic indexes into an N-1 x N matrix of transition probabilities. (The
* parameteriziation in terms of logistic indexes can be useful in doing ML
* estimation).
* %MSPLOGISTIC(p) is the inverse of %MSLOGISTICP - it takes the N-1 x N matrix of
* transition probabilities and returns the implied logistic indexes.
* Revision Schedule:
*  09/2008 Correct initialization of psmooth(end) in %MSSMOOTH
*  01/2009 Add P0 option to %MSSMOOTH to compute pre-sample expected value
*  03/2009 Added %MSSMOOTHCALC which does the smoothing update safeguarded
*          against divide by zero.
*  03/2009 Added %MSLOGISTICP which maps a matrix of logistic index values into
*          an N-1 x N matrix of transition probabilities
function %mcstate p pstar
type vect %mcstate pstar
type rect p
local vect pstub
local integer i
compute pstub=p*pstar
dim %mcstate(%cols(p))
ewise %mcstate(i)=%if(i<=%rows(p),pstub(i),1-%sum(pstub))
function %mcergodic p
type vect %mcergodic
type rect p
local rect a
local integer i j n
compute n=%cols(p)
dim a(n+1,n)
ewise a(i,j)=%if(i>n,1,(i==j)-%if(i<n,p(i,j),1-%sum(%xcol(p,j))))
compute %mcergodic=%xcol(inv(%innerxx(a))*tr(a),n+1)
function %msupdate f pstar fpt
type vect %msupdate f pstar
type real *fpt
local vector fp
compute fp=f.*pstar
compute fpt=%sum(fp)
* If the f's come in zero, just keep the old pstar. The parameters
* will get rejected anyway since the log(fpt) will be NA.
if %minvalue(pstar)<0.00
   compute %msupdate=pstar,fpt=%na
else
if fpt>0
   compute %msupdate=fp/fpt
else
* Transforms an N-1 x N matrix of logistic indexes into an N-1 x N matrix of
function  %mslogisticp theta
type rect %mslogisticp
type rect theta
local vect    totals
local integer nstates i j
compute nstates=%cols(theta)
dim %mslogisticp(nstates-1,nstates) totals(nstates)
do j=1,nstates
   compute totals(j)=1.0
   do i=1,nstates-1
      compute %mslogisticp(i,j)=exp(theta(i,j)),totals(j)+=%mslogisticp(i,j)
ewise %mslogisticp(i,j)=%mslogisticp(i,j)/totals(j)
* Transforms an N-1 x N matrix of transition probabilities into an N-1 x N
* matrix of logistic indexes.
function  %msplogistic p
type rect %msplogistic
type rect p
local vect    totals
compute nstates=%cols(p)
dim %msplogistic(nstates-1,nstates) totals(nstates)
do j=1,nstates
   do i=1,nstates-1
      compute %msplogistic(i,j)=%if(p(i,j)<=0.0,-20.0,log(p(i,j)))
      compute totals(j)-=p(i,j)
   compute totals(j)=%if(totals(j)<=0.0,-20.0,log(totals(j)))
ewise %msplogistic(i,j)=%msplogistic(i,j)-totals(j)
* This does the smoothing update for a single period, safeguarded against
* divides by zero.
function    %mssmoothcalc pfull pt_t pt1_sm pt1_t
type vector %mssmoothcalc pt_t pt1_sm pt1_t
type rect pfull
local vect pratio(%rows(pfull))
ewise pratio(i) = %if(pt1_t(i)==0.0,0.0,pt1_sm(i)/pt1_t(i))
compute %mssmoothcalc = pt_t.*(tr(pfull)*pratio)
procedure %mssmooth p pt_t pt_t1 psmooth
type rect p
type series[vect] pt_t pt_t1 *psmooth
option vect *p0
local rect pexpand pfull
local integer i j nstates time
local vect pstar
* Expand p to a full nxn matrix
dim pexpand(nstates,nstates-1)
ewise pexpand(i,j)=%if(i==nstates,-1.0,i==j)
compute pfull=pexpand*p
ewise pfull(i,j)=%if(i==nstates,1.0+pfull(i,j),pfull(i,j))
compute pstar=pt_t(%regend())
gset psmooth %regstart() %regend() = pstar
do time=%regend()-1,%regstart(),-1
   gset psmooth time time = %mssmoothcalc(pfull,pt_t,psmooth{-1},pt_t1{-1})
end do time
* If requested, get smoothed pre-sample value as well
if %defined(p0)
   compute p0=%mssmoothcalc(pfull,p0,psmooth(%regstart()),pt_t1(%regstart()))
