MSVARSetup - Markov Switching VAR Support (obsolete)
This is a greatly expanded and improved version of MSVARSetup.src. It includes code for estimating using the EM algorithm, optimization for greater speed, and additional options for model types. There was some generally minor renaming of some functions and options from previous versions.
This is written for version 7 of RATS. It requires the new version of MARKOV.SRC (separate thread) as well.
* Procedure file for Markov switching VAR's. This includes several functions, as
* described below.
* @MSVARSetup( options )
* # list of dependent variables
* Options:
*   LAGS=# of VAR lags [1]
*   STATES=# of states [2]
*   SWITCH=[M]/I/MH/IH
*     In each of these, M indicates a Hamilton-type model where the mean of the
*     series is state-dependent. I indicates the intercept is state-dependent.
*     Those are mutually exclusive. H indicates variances are state-dependent.
*  This creates the following variables which will generally need to be put into a parmset and
*  estimated:
*   P      = nstates-1 x nstates Markov transition matrix
*   THETA  = nstates-1 x nstates logistic indices for transition matrix
*     (P and THETA are alternative representations)
*   MU     = VECTOR[VECTOR] of means/intercepts. MU(j) is the mean/intercept vector at state j
*   PHI    = VECTOR[RECT] of lag coefficients. PHI(j) is the N x N vector of lag
*            coefficients for lag j
*   SIGMA  = SYMMETRIC (covariance matrix) or
*   SIGMAV = VECTOR[SYMMETRIC] for heterogeneous covariance matrices
*  It also sets up the following:
*    Y = VECT[SERIES] of dependent variables
*    PT_T,PT_T1 and PSMOOTH are SERIES[VECT] used for computing and saving the state probabilities
*    MSVARLagState,MSVARTransLookup,MSVARTransProbs,MSVARIntercept and PSTAR are working matrices
* Other procedures and functions:
* @MSVARInitial start gend
*   computes initial guess values for a model already set up
* %MSVARMarginal(pexpand,lags)
*   returns a VECTOR of marginal probabilities for states or tuples of states given an expanded
*   vector of probabilities (pexpand). lags is the number of lags in the tuple. lags=0 is used
*   to get just the current state, 1 gives the pairs of state(t),state(t-1), etc.
* %MSVARFVec(time)
*   returns the vector of likelihoods (*not* in log form) for the (expanded) states at <<time>>.
* %MSVARProb(time)
*   compute the likelihood (not logged) of the model at <<time>> for the current set of
*   parameters. As a side effect, it computes pt_t1(time) and pt_t(time)
* %MSVARInit()
*   does the calculations needed at the start of each function evaluation
* For EM algorithm:
* @MSVAREMGeneralSetup
*   needs to be called before using EM to set up the work arrays
* @MSVAREMStep gstart gend
* @MSVAREStep gstart gend
* @MSVARMStep gstart gend
*   EMStep does the combined E and M steps, EStep does only the E, and MStep does only
*   the M. EMStep and MStep both have options to restrict the set of parameters that
*   are updated, so some can be fixed.
* Revision Schedule:
*   05/2007 Written by Tom Doan, Estima
*   07/2008 Revised to include calculation of the "mask" series for computing
*           probabilities of the states.
*   09/2008 Add <<start>> and <<end>> parameters to MSVARInitial to control range
*   09/2008 Add logic to allow nlags==0 in MSVARInitial
*   01/2009 Split up MSVARInit into separate tasks
*   03/2009 Write EM code
source markov.src
procedure MSVARSetup
option integer  lags	    1
option integer  states   2
option choice   switch   1  M I MH IH
* Parameter vectors
dec rect          p
dec rect          theta
dec vect[vect]    mu
dec vect[rect]    phi
dec vect[symm]    sigmav
dec symm          sigma
* Numbers of various items
dec integer       nvar
dec integer       nstates
dec integer       nlags
dec integer       nexpand
dec vect          pstar
dec series[vect]  pt_t
dec series[vect]  pt_t1
dec series[vect]  psmooth
dec vect[series]  y
dec rect[integer] MSVARLagState
dec rect[integer] MSVARTransLookup
dec vect          MSVARTransProbs
dec vect[vect]    MSVARIntercept
dec vect          MSVARLogDetV
dec vect[symm]    MSVARSigmaInv
dec vect[rect]    MSVARSigmaInvF
dec integer       MSVARMeanSwitch
dec integer       MSVARSigmaSwitch
dec integer       MSVARPhiSwitch
local vect[int] yvec
local integer i j
enter(varying) yvec
compute nvar   =%rows(yvec)
compute nstates=states
compute nlags  =lags
dim y(nvar)
do i=1,nvar
   set y(i) = yvec(i){0}
* Parse out the choices for the switch option
if switch==1.or.switch==3.or.switch==5.or.switch==7
   compute MSVARMeanSwitch=1
else
   compute MSVARMeanSwitch=0
if switch==3.or.switch==4.or.switch==7.or.switch==8
   compute MSVARSigmaSwitch=1
else
   compute MSVARSigmaSwitch=0
if switch==5.or.switch==6.or.switch==7.or.switch==8
   compute MSVARPhiSwitch=1
else
   compute MSVARPhiSwitch=0
* If the means of the series are switching, the number of states for the mean of
* the data is nstates**(nlags+1), since we have to cover every possible
* combination. If we're only switching coefficients in the VAR directly, there
* will only be nstates distinct possibilities.
if MSVARMeanSwitch
   compute nexpand=nstates**(nlags+1)
else
* MSVARLagState(i,j) is a lookup table for the state of expanded state "i" at lag j-1.
dim MSVARLagState(nexpand,nlags+1)
if MSVARMeanSwitch==1
   ewise MSVARLagState(i,j)=1+%mod((i-1)/nstates**(nlags+1-j),nstates)
else
   ewise MSVARLagState(i,j)=i
* We also create a mapping from state to state which will pick out the transition
* probability. MSVARTransLookup will be a number from 1 to nstates**2+1. 1 is the most
* common value, which represents a zero transition probability. For instance, in a
* two state setting with current + four lags, if we're in (1,1,2,2,1), the only
* states which can be obtained are {1,1,1,2,2} and {2,1,1,2,2}. The transition
* probability to the first of these would be p(1,1), and for the second it would be
* 1-p(1,1). Given our coding, it's easy to tell whether a state can be obtained from
* another, since the final nlags spots of the new state have to be the same as the
* lead nlags spots of the old state.
dim MSVARTransLookup(nexpand,nexpand) MSVARTransProbs(1+nstates**2)
   ewise MSVARTransLookup(i,j)=fix(%if(%mod(i-1,nstates**nlags)==(j-1)/nstates,$
       nstates*(MSVARLagState(i,1)-1)+MSVARLagState(j,1)+1,1))
else
   ewise MSVARTransLookup(i,j)=(i-1)*nstates+j+1
* The transition probabilities are parameterized as an nstates-1 x nstates matrix.
* Each column gives the transition probabilities out of a particular state to the
* first nstates-1 states. The theta array is used for an alternative
* parameterization using logistics.
dim p(nstates-1,nstates) theta(nstates-1,nstates) pstar(nexpand)
dim   mu(nstates)
ewise mu(i) =%zeros(nvar,1)
dim   phi(nlags)
ewise phi(i)=%zeros(nvar,nvar)
dim   MSVARIntercept(nexpand)
ewise MSVARIntercept(i)=%zeros(nvar,1)
dim   sigmav(nstates)
dim   MSVARLogDetV(nstates)
dim   MSVARSigmaInv(nstates)
dim   MSVARSigmaInvF(nstates)
function %MSVARLookupTable nstates nlags
type rect[integer] %MSVARLookupTable
type integer nstates nlags
local integer i j
* Returns a lookup table(i,j) for the state of expanded state <<i>> at lag <<j>>+1
dim   %MSVARLookupTable(nstates^(nlags+1),nlags+1)
ewise %MSVARLookupTable(i,j)=1+%mod((i-1)/nstates**(nlags+1-j),nstates)
function %MSVARMarginal pexpand lags
type     vector  %MSVARMarginal
type     vector  pexpand
type     integer lags
local integer targetSize perTarget
compute targetSize=nstates^(lags+1)
dim %MSVARMarginal(targetSize)
compute perTarget=%rows(pexpand)/targetSize
compute %MSVARMarginal=%fill(1,perTarget,1.0)*%vectorect(pexpand,perTarget)
* Computes a standard set of initial guess values for the parameters
procedure MSVARInitial start end
type integer  start end
local integer i j l
local model   olsmodel
local rect    crect
do i=1,nvar
   stats(noprint,fractiles) y(i) start end
   if nstates==2 {
      compute mu(1)(i)=%fract90
      compute mu(2)(i)=%fract10
   else
   if nstates==3 {
      compute mu(2)(i)=%median
      compute mu(3)(i)=%fract10
system(model=olsmodel)
variables y
if nlags>0
   lags 1 to nlags
estimate(noprint) start end
compute crect=%modelgetcoeffs(olsmodel)
do i=1,nvar
   do l=1,nlags
      do j=1,nvar
         ewise phi(l)(i,j)=crect((j-1)*nlags+l,i)
   end do l
if MSVARMeanSwitch==0
   ewise mu(i)=%modellagsums(olsmodel)*mu(i)
ewise sigmav(i)=%sigma
compute sigma=%sigma
ewise p(i,j)=%if(i==j,.8,.2/(nstates-1))
compute theta=%MSPLogistic(p)
* Returns the vector of likelihoods (*not* in log form) for the (expanded)
* states at <<time>>.
function %MSVARFVec time
type vector  %MSVARFVec
type integer time
local integer i j state
local vect    u
dim %MSVARFVec(nexpand)
compute u=%xt(y,time)
do j=1,nlags
   compute u=u-phi(j)*%xt(y,time-j)
do i=1,nexpand
   compute state=MSVARLagState(i,1),$
      %MSVARFVec(i)=exp(-.5*MSVARLogDetV(state)-.5*%qform(MSVARSigmaInv(state),u-MSVARIntercept(i)))
function %MSVARProb time
type real    %MSVARProb
type integer time
local integer i j
local vect    p f fp
local real    sp fpt
dim p(nexpand)
compute f=%MSVarFVec(time)
do i=1,nexpand
   compute sp=0.0
   do j=1,nexpand
      compute sp=sp+MSVARTransProbs(MSVARTransLookup(i,j))*pstar(j)
   compute p(i)=sp
compute pt_t1(time)=p
compute fp=f.*p
compute fpt=%sum(fp)
compute pstar=fp*(1.0/fpt)
compute pt_t(time)=pstar
compute %MSVARProb=fpt
function %MSVARInitIntercepts
local integer i j
* Initializes the MSVARIntercept array given the current settings for the lag
* coefficients and mu array. This has no usable return value.
if nexpand==nstates
   ewise MSVARIntercept(i)=mu(i)
else {
   do i=1,nexpand
      compute MSVARIntercept(i)=mu(MSVARLagState(i,1))
      do j=1,nlags
         compute MSVARIntercept(i)=MSVARIntercept(i)-phi(j)*mu(MSVARLagState(i,j+1))
function %MSVARInitVariances
* Initializes the sigmav array given the current settings for the sigma's
* This has no usable return value
local integer i
local vector  eigval
local rect    eigvect
do i=1,nstates
   if MSVARSigmaSwitch==0 {
      compute sigmav(i)=sigma
      if i>1 {
         compute MSVARLogDetV(i)  =MSVARLogDetV(i-1)
         compute MSVARSigmaInv(i) =MSVARSigmaInv(i-1)
         compute MSVARSigmaInvF(i)=MSVARSigmaInvF(i-1)
         next
   compute MSVARLogDetV(i)=0.0
   eigen sigmav(i) eigval eigvect
   do j=1,nvar
      if eigval(j)<1.e-10
         compute eigval(j)=1.e-10
      compute MSVARLogDetV(i)+=(log(eigval(j))+1.837877066409345)
      compute eigval(j)=1.0/eigval(j)
   compute MSVARSigmaInv(i) =eigvect*%diag(eigval)*tr(eigvect)
   compute MSVARSigmaInvF(i)=%diag(%sqrt(eigval))*tr(eigvect)
function  %MSVARInitTransition
type real %MSVARInitTransition
local integer i row col
ewise MSVARTransProbs(i)=row=(i-2)/nstates+1,col=%clock(i-1,nstates),$
  %if(i==1,0.0,%if(row==nstates,1-%sum(%xcol(p,col)),p(row,col)))
* Return "false" (real zero) if any of the transition probabilities are negative
ewise MSVARTransProbs(i)=%if(abs(MSVARTransProbs(i))<.00001,0.0,MSVARTransProbs(i))
compute %MSVARInitTransition=(%minvalue(MSVARTransProbs)>=0.0)
function    %MSVARInit
type vector %MSVARInit
local rect a
local integer i j
* If any of the transition probabilities are negative, the parameter setting will
* be rejected.
if %MSVARInitTransition()==0.0 {
   compute %MSVARInit=%zeros(nexpand,1)
   return
compute %MSVARInitIntercepts()
compute %MSVARInitVariances()
dim a(nexpand+1,nexpand)
ewise a(i,j)=%if(i>nexpand,1.0,(i==j)-MSVARTransProbs(MSVARTransLookup(i,j)))
compute %MSVARInit=%xcol(inv(tr(a)*a)*tr(a),nexpand+1)
procedure MSVARStaticForecast start end yfore
type vect[series]  *yfore
option series[vect] phat pt_t1
local integer time l k
local vector  yvec
dim yfore(nvar)
do k=1,nvar
   set yfore(k) start end = 0.0
end do k
do time=start,end
   compute yvec=%zeros(nvar,1)
   do l=1,nlags
      compute yvec=yvec+phi(l)*%xt(y,time-1)
   end do l
   do k=1,nexpand
      compute yvec=yvec+phat(time)(k)*MSVARIntercept(k)
   end do k
   compute %pt(yfore,time,yvec)
end do time
* EM requires smoothed probabilities of all combinations of {S(t),S(t-1)}. When
* the means are switching, we need to compute the smoothed probabilities of all
* combinations of {S(t),...,S(t-p)} anyway, so we can just compute the above
* probabilities by marginalizing.
declare rect[int] EMLagState
declare integer   EMsize
declare integer   EMCMomSize
dec series[vect]  EMPT_T
dec series[vect]  EMPT_T1
dec series[vect]  EMPTSM
dec rect[rect]    EMMBlock
dec vect[vect]    EMYBlock
declare vector    EMP0
procedure MSVAREMGeneralSetup
* We need to do (at minimum) pairs of S(t),S(t-1). If we had to expand states
* anyway, we're all set. If not, we need to set up an nstates^2 array of lag
* states.
if nexpand==nstates {
   compute EMsize=nstates^2
   compute EMLagState=%MSVARLookupTable(nstates,1)
else {
   compute EMsize=nexpand
   compute EMLagState=MSVARLagState
dim EMMBlock(nstates,nstates)
dim EMYBlock(nstates)
if MSVARSigmaSwitch
   compute EMCMomSize=nvar^2*nlags
else
   compute EMCMomSize=nvar*(nlags+1)
compute EMP0=%fill(nexpand,1,1.0/nexpand)
function %MSVARInitEM
type vector %MSVARInitEM
compute %MSVarInit()
compute %MSVARInitEM=EMP0
function  %MSVARPmat  time
type rect %MSVARPmat
type int  time
local integer i j
local rect    pexpand
   dim pexpand(nstates,nstates-1)
   ewise pexpand(i,j)=%if(i==nstates,-1.0,i==j)
   compute %MSVARPmat=pexpand*p
   ewise %MSVARPmat(i,j)=%if(i==nstates,1.0+%MSVARPmat(i,j),%MSVARPmat(i,j))
else {
   dim %MSVARPmat(nexpand,nexpand)
   ewise %MSVARPmat(i,j)=MSVARTransProbs(MSVARTransLookup(i,j))
* Does the "E" step for EM, computing the smoothed probabilities of pairs of
* states at t and t-1.
procedure MSVAREStep gstart gend
type integer gstart gend
option switch ergodic 0
local integer time i j
local rect    pfull pexpandx
local vect    pstar f
local integer targetstate sourcestate
local real    ptt ft
* EM calculations for transitions
gset EMPT_T1 gstart gend = %zeros(EMSize,1)
gset EMPT_T  gstart gend = %zeros(EMSize,1)
gset EMPTSM  gstart gend = %zeros(EMSize,1)
compute %logl=0.0
if ergodic==0
   compute pstar=%MSVARInitEM()
else
   compute pstar=%MSVARInit()
compute EMP0=pstar
do time=gstart,gend
   * This is either dimension <<nstates>> or <<nexpand>> depending upon
   * the type of switching.
   compute f=%MSVARFvec(time)
   * This is the full <<nstates>> x <<nstates>> or <<nexpand>> x <<nexpand>>
   * array of transition probabilities.
   compute pfull=%MSVARPmat(time)
   * Compute the probabilities for expanded state i
   do i=1,EMSize
      do j=1,EMSize
         compute targetState=EMLagState(i,1)
         compute sourceState=EMLagState(j,1)
         if nstates==nexpand {
            if EMLagState(j,2)<>1.or.EMLagState(i,2)<>sourceState
               next
            compute ptt=pfull(targetState,sourceState)*pstar(sourceState)
            compute ft =f(targetState)
         else {
            compute ptt=pfull(i,j)*pstar(j)
            compute ft=f(i)
         compute EMPT_T1(time)(i)=EMPT_T1(time)(i)+ptt
         compute EMPT_T(time)(i) =EMPT_T(time)(i) +ptt*ft
   compute %logl=%logl+log(%sum(EMPT_T(time)))
   compute EMPT_T1(time)=EMPT_T1(time)/%sum(EMPT_T1(time))
   compute EMPT_T(time) =EMPT_T(time)/%sum(EMPT_T(time))
   * Marginalize this to get the current state
   if nstates==nexpand
      compute pstar=%MSVARMarginal(EMPT_T(time),0)
   else
      compute pstar=EMPT_T(time)
end do time
* Compute smoothed probabilities
compute EMPTSM(gend)=EMPT_T(gend)
compute pfull=%MSVARPmat(gend)
if %rows(pfull)<>EMSize {
   dim pexpandx(EMSize,EMSize)
   ewise pexpandx(i,j)=%if(EMLagState(i,2)==EMLagState(j,1),pfull(EMLagState(i,1),EMLagState(j,1)),0.0)
else
   compute pexpandx=pfull
do time=gend-1,gstart,-1
   compute EMPTSM(time)=%mssmoothcalc(pexpandx,EMPT_T(time),EMPTSM(time+1),EMPT_T1(time+1))
end do time
if nexpand<>nstates
   compute EMP0=%mssmoothcalc(pexpandx,EMP0,EMPTSM(gstart),EMPT_T1(gstart))
else
   compute EMP0=%vectorect(EMPTSM(gstart),nstates)*%fill(nstates,1,1.0)
* Does the "M" step of EM, updating the various sets of coefficients.
procedure MSVARMStep gstart gend
option switch domu    1
option switch dovar   1
option switch dosigma 1
option switch dop     1
local integer time i j k s lag
local integer notthere
local rect    phimat phisum
local vect    qhat mublock
local rect    xxem testxx
local rect    sxem
local vect    xem yvec xvec xyem
local rect    EMPTSMsum
local vect    qsum
local vect    sumwts
local rect    phistack
local rect    ifactor
if MSVARPhiSwitch {
else {
   * Compute the means or intercepts given the previous VAR coefficients
   if domu==0
      branch skipmu
   if MSVARMeanSwitch==0 {
      *  Switching intercepts is easy because there's no multiplicative relationship
      *  between the VAR coefficients and the intercepts. It's just a weighted average
      *  of means of the residuals from the VAR
      ewise EMYBlock(i)=%zeros(nvar,1)
      compute sumwts=%zeros(nstates,1)
      do time=gstart,gend
         compute qhat=%MSVARMarginal(EMPTSM(time),0)
         compute yvec=%xt(y,time)
         do lag=1,nlags
            compute yvec=yvec-phi(lag)*%xt(y,time-lag)
         end do lag
         ewise EMYBlock(s)=EMYBlock(s)+qhat(s)*yvec
         ewise sumwts(s)=sumwts(s)+qhat(s)
      end do time
      ewise mu(s)=EMYBlock(s)/sumwts(s)
   else {
      ewise EMMBlock(i,j)=%zeros(nvar,nvar)
      do s=1,nstates
         do k=1,nexpand
            compute phisum=%zeros(nvar,nvar)
            compute notthere=1
            do lag=0,nlags
               if lag==0
                  compute phimat = -1.0*%identity(nvar)
               else
                  compute phimat = phi(lag)
               if MSVARLagstate(k,lag+1)==s
                  compute phisum=phisum+phimat,notthere=0
            end do lag
            if notthere
               next
            if MSVARSigmaSwitch
               compute phisum=tr(phisum)*MSVARSigmaInv(MSVARLagState(k,1))
            else
               compute phisum=tr(phisum)*MSVARSigmaInv(1)
            do time=gstart,gend
               compute qhat=EMPTSM(time)
               do lag=0,nlags
                  if lag==0
                  else
                  compute EMYBlock(s)=EMYBlock(s)+qhat(k)*phisum*phimat*%xt(y,time-lag)
                  compute EMMBlock(s,MSVARLagState(k,lag+1))=EMMBlock(s,MSVARLagState(k,lag+1))+qhat(k)*phisum*phimat
               end do lag
            end do time
         end do k
      end do s
      compute mublock=%solve(%BLOCKGLUE(EMMBlock),%BLOCKGLUE(EMYBlock))
      do i=1,nstates
         compute mu(i)=%xsubvec(mublock,nvar*(i-1)+1,nvar*i)
:skipmu
   * Compute VAR lag coefficients given the new means or intercepts
   if dovar==0
      branch skipvar
      * With sigma not being state-dependent, this can be done simply
      * as a multivariate regression with state-dependent weights on
      * the observations.
      compute xxem=%zeros(EMCMomSize,EMCMomSize)
      compute xem =%zeros(EMCMomSize,1)
      do k=1,nexpand
         do time=gstart,gend
            if MSVARMeanSwitch
            else
            compute xem=%const(0.0)
            compute yvec=%xt(y,time)-mu(MSVARLagState(k,1))
   			compute %psubvec(xem,1,yvec)
            do lag=1,nlags
               compute xvec=%xt(y,time-lag)
               if MSVARMeanSwitch
                  compute xvec=xvec-mu(MSVARLagState(k,lag+1))
   				compute %psubvec(xem,1+nvar*lag,xvec)
            end do lag
            compute xxem=xxem+qhat(k)*%outerxx(xem)
         end do time
      end do k
      compute testxx=%sweeplist(xxem,%seq(nvar+1,EMCMOMSize))
      do lag=1,nlags
         compute phi(lag)=tr(%xsubmat(testxx,1+nvar*lag,nvar*(lag+1),1,nvar))
      end do lag
   else {
      * With state-dependent sigmas, this is a more time-consuming weighted
      * SUR.
      compute xyem=%zeros(EMCMomSize,1)
      compute xem =%zeros(nvar*nlags,1)
      do k=1,nexpand
         compute ifactor=MSVARSigmaInvF(MSVARLagState(k,1))
         do time=gstart,gend
            if MSVARMeanSwitch
            else
            compute yvec=ifactor*(%xt(y,time)-mu(MSVARLagState(k,1)))
            do lag=1,nlags
               if MSVARMeanSwitch
   				compute %psubvec(xem,1+nvar*(lag-1),xvec)
            end do lag
            compute sxem=%kroneker(ifactor,tr(xem))
            compute xxem=xxem+qhat(k)*%innerxx(sxem)
            compute xyem=xyem+qhat(k)*tr(sxem)*yvec
         end do time
      end do k
      compute phistack=tr(%vectorect(%solve(xxem,xyem),nvar*nlags))
      do lag=1,nlags
         compute phi(lag)=%xsubmat(phistack,1,nvar,1+nvar*(lag-1),nvar*lag)
      end do lag
:skipvar
   if dosigma==0
      branch skipsigma
   if MSVARSigmaSwitch==0.and.MSVARMeanSwitch.and.dovar {
      * We can do this as a side-effect of the multivariate regression
      compute sigma=%xsubmat(testxx,1,nvar,1,nvar)/(gend-gstart+1)
   else {
      if MSVARSigmaSwitch
         ewise sigmav(i)=%zeros(nvar,nvar)
      else
         compute sigma=%zeros(nvar,nvar)
      do time=gstart,gend
         if MSVARMeanSwitch
         else
         do k=1,nexpand
            do lag=1,nlags
               if MSVARMeanSwitch
               compute yvec=yvec-phi(lag)*xvec
            end do lag
            if MSVARSigmaSwitch {
               compute sigmav(MSVARLagState(k,1))=sigmav(MSVARLagState(k,1))+qhat(k)*%outerxx(yvec)
               compute sumwts(MSVARLagState(k,1))+=qhat(k)
            else
               compute sigma=sigma+qhat(k)*%outerxx(yvec)
         end do k
      end do time
      if MSVARSigmaSwitch
         ewise sigmav(i)=sigmav(i)/sumwts(i)
      else
         compute sigma=sigma/(gend-gstart+1)
:skipsigma
*	  Update P. For an expanded set of states, we need to marginalize to
*    the pairs of (S(t),S(t-1))
   if dop==0
      branch skipp
   compute EMPTSMsum=%zeros(nstates,nstates)
   do time=gstart,gend
      do k=1,EMSize
         compute EMPTSMsum(EMLagState(k,1),EMLagState(k,2))+=EMPTSM(time)(k)
      end do k
   end do time
   compute qsum=%fill(1,nstates,1.0)*EMPTSMsum
   ewise p(i,j)=EMPTSMsum(i,j)/qsum(j)
:skipp
end MSVAREMStep
* MSVAREMStep does a single step (both "E" and "M") for a Markov switching VAR
* The "M" step in most cases will be a generalized "M" step, is the sense that
* it doesn't maximize the likelihood given the smoothed probabilities for the
* states, but just increases it.
procedure MSVAREMStep gstart gend
option switch dop     1
@MSVAREStep(ergodic=ergodic) gstart gend
@MSVARMStep(domu=domu,dovar=dovar,dosigma=dosigma,dop=dop) gstart gend
* Does a function evaluation for the EM algorithm. The function value is in %logl
procedure MSVAREMEval gstart gend
local vector  f pstar fp
local rect    pfull
local integer time
local real    sumfp
compute %logl=0.0
if ergodic==0
else
do time=gstart,gend
   compute fp=%zeros(nexpand,1)
   do i=1,nexpand
      do j=1,nexpand
         compute fp(i)=fp(i)+f(i)*pfull(i,j)*pstar(j)
   compute sumfp=%sum(fp)
   compute pstar=fp/sumfp
   compute %logl=%logl+log(sumfp)
end do time
This is an example of a six variable, two stage, one lag VAR with switching means.
* MS(2)-VAR(1) model
source msvarsetup.src
open data wbc.xls
calendar(q) 1960
data(format=xls,org=columns) 1960:1 1991:4 usa can uk frg jap aus d73q3
set dusa = usa-usa{1}
set djap = jap-jap{1}
set dfrg = frg-frg{1}
set duk  = uk-uk{1}
set dcan = can-can{1}
set daus = aus-aus{1}
compute gstart=1962:1,gend=1991:4
@msvarsetup(lags=1,states=2)
# dusa djap dfrg duk dcan daus
* EM iterations from the standard guess values. This hits a stationary point with
* a lower log likelihood. This is basically decomposing the sample into recession
* and expansion states.
@msvarinitial gstart gend
@msvarEMgeneralsetup
do emits=1,50
   @msvaremstep gstart gend
   disp "Iteration" emits "Log Likelihood" %logl
end do emits
disp "mu(1)=" mu(1)
disp "mu(2)=" mu(2)
disp "P=" p
set smoothp1 gstart gend = pstar=%MSVARMarginal(EMPTSM(t),0),pstar(1)
graph(footer="Recession/Expansion Mode")
# smoothp1
* These are Krolzig's values for the mu's. From here, we pretty much reproduce his
* results until the p matrix produces an absorbing state.
input mu(1)
 1.0951 2.2973 1.1473 0.8920 1.4705 1.4651
input mu(2)
 0.4749 0.9422 0.4920 0.3717 0.6735 0.6097
do emits=1,50
end do emits
* These are almost imperceptibly different from the ones above, but seem to avoid
* the absorbing state, and produce a higher log likelihood
input mu(1)
  1.03093  2.81999  1.23774  1.01214  1.37031  1.57119
input mu(2)
  0.58775  1.00435  0.57165  0.42210  0.82514  0.71478
do emits=1,50
end do emits
disp "mu(1)=" mu(1)
disp "mu(2)=" mu(2)
disp "P=" p
graph(footer="End of Golden Age Mode")
# smoothp1
* Full sample ML
* With some effort (it nearly gets stuck at a lower log L), this converges to same
* basic model as just estimated
nonlin(parmset=varparms) mu phi sigma
nonlin(parmset=msparms) theta
gset pt_t  gstart gend = %zeros(nexpand,1)
gset pt_t1 gstart gend = %zeros(nexpand,1)
frml msvarf = log(%MSVARProb(t))
maximize(trace,parmset=varparms+msparms,start=%(p=%mslogisticp(theta),pstar=%MSVARInit()),$
  reject=%minvalue(MSVARTransProbs)<0.0,method=bfgs,iters=400) msvarf gstart gend
do emits=1,30
end do emits
m joaorodrigues
Re: MSVARSetup - Markov Switching VAR Support
Unread post by m joaorodrigues »
Hi there,
I was wondering if anybody knows the codes to get the variance-covariance matrix associated to the transition probabilities, just as in Altavilla (2004), "Do EMU members share the same Business Cycle?", JCMS Vol. 42,Number 5, pp 869-896 who used RATS codes to perform Markov switching estimations (see footnote note 1 on page 872).
In page 880 and 883 he uses those variances-covariances to perform wald tests.
If you estimate the model using MAXIMIZE, you get a covariance matrix of the full parameter set. The example above does that at the end. EM is quite a bit faster, but doesn't naturally give a covariance matrix since it estimates parameters a piece at a time. With the improved coding, MAXIMIZE is generally acceptably quick for any but really big models. (Six variables, four lags might take a bit longer than you might like). One possibility is to use EM to do most of the work, then use one iteration of MAXIMIZE with METHOD=BHHH. (You can't use BFGS with nearly converged estimates because it won't have enough iterations to determine the local curvature).
Tom Doan
Estima
