How do I append an equation to a group in a loop?
macro
Unread post by macro »
For example, in this code:
dofor s = gdp cons gce gov
    linreg(define = eq) s
    # unemp{1 to 4}
    group my_model eq>>s
end dofor s
display %modelsize(my_model)
the result is a model with only one equation, because the model is overwritten by each group statement in the loop. How do I append equations to a model, in a loop or otherwise?
Re: How do I append an equation to a group in a loop?
You can use model=model+equation
declare model my_model
    # unemp{1 to 4}
    compute my_model=my_model+eq
end dofor s
macro
Perfect! And it supports any variable with the model type, even items from a hash[model] aggregator. Thank you!
