How do I merge values from a file into a series in memory?
macro
Unread post by macro »
I have a series in memory, and I have a file that contains the same series with a subsample of dates. I'm trying to merge the series in the file with the series already in memory, overwriting values in the original series that occur in the file, while leaving the rest of the series intact. Here's a simple example:
calendar(q) 1940:1
* load original data
open data nipa.csv
    data(format = cdf, org = columns, dateform = "m/d/y") / gdp
close data
print 2013:1 2015:4 gdp
* merge new values
open data new_values.csv
    data(format = cdf, org = columns) / gdp
close data
This produces the output
* <snipped>
 ENTRY          GDP
 2013:01      15457.2
 2013:02      15500.2
 2013:03      15614.4
 2013:04      15761.5
 2014:01      15724.9
 2014:02      15901.5
 2014:03      16068.8
 2014:04      16151.4
 2015:01      16177.3
 2015:02      16270.4
 2015:03        NA
 2015:04        NA
* merge new value
close data
 ENTRY          GDP
 2013:01        NA
 2013:02        NA
 2013:03        NA
 2013:04        NA
 2014:01         -1
 2014:02        NA
 2014:03        NA
 2014:04        NA
 2015:01        NA
 2015:02         -2
 2015:03         -3
 2015:04        NA
whereas I'm trying to get the gdp series to look like this:
 ENTRY          GDP
 2013:01      15457.2
 2013:02      15500.2
 2013:03      15614.4
 2013:04      15761.5
 2014:01      -1
 2014:02      15901.5
 2014:03      16068.8
 2014:04      16151.4
 2015:01      16177.3
 2015:02      -2
 2015:03      -3
 2015:04      -4
The dates and values in new_values.csv are completely arbitrary and aren't known ahead of time (except that they'll be in the same frequency as the series currently in memory). Is this possible?
new_values.csv
(54 Bytes) Downloaded 861 times
nipa.csv
(4.65 KiB) Downloaded 839 times
Re: How do I merge values from a file into a series in memor
You can read the second series into a different name (or read the patch first and make a copy under a different name), then use %IF to patch over values that are not NA in the patch series.
calendar(q) 1940:1
open data nipa.csv
close data
 * merge new values
   data(format = cdf,top=2, org = columns) / gdpnew
close data
set gdp = %if(%valid(gdpnew),gdpnew,gdp)
