## Unassigned 1803 Error
Anja
Unread post by Anja »
does anyone know what this error means?
It occurs when I'm reading in data which (to me) looks no different to any other series.... Its the Linux version of Rats.
Thanks!
Re: ## Unassigned 1803 Error
That's a "Can't Open File" message. In batch mode, if you try to use a file but have the wrong path or name, you'll get that message.
You might want to check with whomever installed RATS, because your error message file (ratserrs.msg) isn't being found.
