Is there a better way to show the output from a subset VAR?
macro
Unread post by macro »
I have code that estimates a subset VAR equation-by-equation:
calendar(q) 1947 1
open data data.csv
data(format = cdf, org = columns) 1970:1 2015:2 $
    gdph cdh ffed lr
close data
report(action = define, hlabels = ||"Regressor", "GDP", "Consumption"||)
linreg(print, define = eq1) gdph
# ffed{3 to 6} lr{1 2 4}
report(regress)
linreg(print, define = eq2) cdh
# ffed{1 to 3} lr{2 to 5}
report(regress)
report(action = show)
As of now, this displays
Regressor      GDP      Consumption
FFED{3}      19.480062   -78.183085
           (357.632048)  (30.797323)
FFED{4}     -11.990367
           (519.483880)
FFED{5}     222.054116
           (501.160617)
FFED{6}    -799.431959
           (324.080446)
LR{1}      3427.362050
          (1170.225960)
LR{2}     -2746.678519   309.339318
          (1675.606390) (113.060738)
LR{4}      1311.521907  -245.343544
           (681.659189) (195.535344)
FFED{1}                  -35.602207
                         (27.747893)
FFED{2}                   54.292665
                         (42.386350)
LR{3}                   -233.190892
                        (202.358697)
LR{5}                    307.194045
                         (99.820578)
because any lags that aren't in the first equation are appended to the end of the regression list in the report, instead of slotted in to where they would belong if I was writing the model out by hand, where all variables have all their lags in order, e.g. FFED{1}, FFED{2}, ... LR{1}, LR{2}, ... etc.
Is there a way to display the coefficients and std errors (or tstats) from this VAR using report, or should I roll my own using some combination of %tablefromrl to fill in missing lags with blanks in each equation?
data.csv
(5.67 KiB) Downloaded 1021 times
Re: Is there a better way to show the output from a subset V
You can force a particular order by seeding in the regressors column (leaving a blank line between each regressor). For instance:
report(action=define,title="Estimated Models for DOCVIS",$
 hlabels=||"Variable","Poisson","Negbin 2","Negbin 2 Het.","Negbin 1","Negbin P"||)
* Fill in the column with row labels
report(atrow=1,atcol=1,fillby=cols) "Constant" "" "Age" "" "Education" "" "Income" $
 "" "Kids" "" "Public" "" "P" "" "Alpha" "" "Female" "" "Married" "" "LnL"
macro
Thank you. This is the code I'm using, and it works well.
calendar(q) 1947 1
open data data.csv
    gdph cdh ffed lr
close data
* estimate one equation of the VAR to get the regressor labels
linreg(noprint) gdph
# ffed{1 to 6} lr{1 to 6} constant
compute labels = %eqnreglabels(0)
declare vector[string] report_labels(2*%size(labels))
ewise report_labels(i) = %if(%mod(i,2) == 1, labels(fix(i/2)+1), "")
report(action = modify, atrow = 1, atcol = 1, fillby = cols) report_labels
# ffed{3 to 6} lr{1 2 4} constant
report(regress)
linreg(noprint) cdh
# ffed{1 to 3} lr{2 to 5} constant
report(regress)
