draw from truncated normal
PTillmann-436
Dear all,
I want to draw a latent variable from a truncated normal. Here I repeat the crucial commands. First, I specifiy two policy actions, easing and tightening:
set easing= loose ==1.0
set tighhtening= tight ==-1.0
set ystar = %if(tightening,-1.0,%if(easing,1.0,0.0))
The latent variable should be above 1 for easing, below -1 for tightening and between 1 and -1 otherwise:
compute ystar(time)=%if(easing(time),%rantruncate(cmean,cstddev,1.0,%na),$
%if(tightening(time),%rantruncate(cmean,cstddev,%na,-1.0),$
%rantruncate(cmean,cstddev,-1.0,1.0)))
The problem is that the estimated ystar is never below -1 despite several tightening observations. Where is the flaw?
Thanks a lot for your help.
Re: draw from truncated normal
You clearly left out a bunch of code that might be important. The following seems to work fine:
Is it possible that you don't have the loop over TIME set up properly?
set loose 1 500 = %ranflip(.1)
set tight 1 500 = %if(.not.loose,-%ranflip(.1),0.0)
set easing = loose==1.0
set tightening = tight ==-1.0
compute cmean=0.0,cstddev=2.0
clear ystar
do time=1,500
end do time
PTillmann-436
Thanks for your prompt response. I am trying to generalize the codes for Dueker's Qual VAR from binary data to three alternative realizations.
Thanks again!
Thanks again!
Are you sure you have data points where tightening is non-zero and easing is zero, that is, have you checked whether the part of the program that's setting up your dummies is correct?
PTillmann-436
I think it is now working (see graph). The tightening/easing periods are observed and plotted as shaded areas. The VAR-part seems to add little information as the latent variable mostly reflects the +1/-1 dummies, but at least the code seems to work.
- Graph.pdf
- (11.56 KiB) Downloaded 919 times
