Debugging
fan
Debugging
Unread post by fan »
hi tom, i am trying replicate the example in Kim&Nelso (KIMNP126.RPF). However, the following error message appears. I checked the example code, couldn't find the error. Could you please take a look?by the way, what can be the best and a quick way to get the line numbers to check and debug?
The Error Occurred At Location 170, Line 13 of %MSINIT
Called From Location 127, Line 13 of MSFILTERINIT
s&w.xls
(46.52 KiB) Downloaded 1167 times
kimnp126.rpf
(7.16 KiB) Downloaded 1164 times
Re: Debugging
That needs the same fix as in your program. (@MSFilterInit probably was changed to do an additional calculation after the original program was written).
https://estima.com/forum/viewtopic.php?p=11268#p11268
