Generating dummies using a loop
alexecon
Unread post by alexecon »
The following creates a dummy that takes the value 1 in the first calendar month of a daily dataset, calculates basic stats of the variable MYSERIES for that month, and, finally, replaces the 1 values of the dummy with the standard deviation for MYSERIES:
SET DUMMY1 = T>=2001:01:01.AND.T<2001:02:01
STATS(SMPL=DUMMY1) MYSERIES
SET(smpl=dummy1) DUMMY1 = sqrt(%variance)
How does one create a loop to do this for each month in a multi-year dataset?
Re: Generating dummies using a loop
This is an example:
cal(d) 1947:1:1
all 1990:12:31
set junk = %ran(1.0)
set yymm = %year(t)*100+%month(t)
panel(group=yymm,id=yymmvalues)
set mysd 1 %size(yymmvalues) = %na
do i=1,%size(yymmvalues)
   stats(noprint,smpl=(yymm==yymmvalues(i))) junk
   compute mysd(i)=sqrt(%variance)
alexecon
TomDoan wrote:This is an example:
cal(d) 1947:1:1
all 1990:12:31
Thank you -this worked. I would like to do the same for the correlations between two variables. Would you be able to direct me as to what my commented line in the code below should include?
cal(d) 1947:1:1
all 1990:12:31
set morejunk = %ran(1.0)
panel(group=yymm,id=yymmvalues)set mycorrs 1 %size(yymmvalues) = %na
   * what instruction should I use here that produces %corr?
   compute mycorrs(i) = %corr(junk,morejunk)
   cmom(corr,smpl=(yymm==yymmvalues(i)))
   # junk morejunk
   compute mycorrs(i) = %cmom(1,2)
