Assigning values and obtaining information from ARRAYS
jjulioro
Unread post by jjulioro »
Dear all,
In my code I calculate at every time the realized volatility matrix of a set of financial prices which is output to a SYMMETRIC[REAL] object called VCVMAT.
I have also declared two different objects, a SYMMETRIC[SERIES] and a VECTOR[SYMMETRIC[REAL]] called MVOLATS and SIGMAS respectively
COMPUTE NVAR = 4
DECLARE SYMMETRIC[SERIES] MVOLATS(NVAR,NVAR)
DECLARE VECTOR[SYMMETRIC[REAL]] SIGMAS
Through a loop I can assign and recover single scalars and SYMMETRIC matrices from MVOLATS.
I believe it is more efficient to use the VECTOR[SYMMETRIC[REAL]] object, but have not found the way to assign or recover each SYMMETRIC matrix component or any single scalar from and to the VECTOR[SYMMETRIC[REAL]] object.
Could you please point me out on how to declare, assign and recover single scalars and msymmetric matrices to and from a VECTOR[SYMMETRIC[REAL]] object?
I appreciate very much your help.
JMJulio.
Re: Assigning values and obtaining information from ARRAYS
If you have a VECT[SYMM] called myvs, then
myvs(k) is the kth symmetric matrix and
myvs(k)(i,j) is the i,j element of the k's symmetric matrix.
jjulioro
Great!
Thank you.
Is there anywhere else I can read about how theses objects work?
JMJulio
Not really. The VECT[SERIES] (RECT[SERIES], SYMM[SERIES]) tend to be more natural. SERIES[VECT], SERIES[RECT], SERIES[SYMM] get used more when you need to manipulate the full matrices---however, with the %XT function, you can easily pull out a time-slice from a matrix[SERIES], so there isn't that big an advantage to the SERIES[matrix] arrangement.
