Question about guess values in MS models
fan
Unread post by fan »
Hi Tom, could you please kindly help me understand the code
compute temp=mu(3), mu(3)=mu(1),mu(1)=temp
in example KIMNP082.RPF?
* KIMNP082.RPF
* 4.5 Application 2 from pp 82-86 of Kim and Nelson, "State-space Models
* with Regime Switching"
* MS AR model with switches in mean and variance.
open data int_cpuq.prn
calendar(q) 1947:1
data(format=free,org=columns) 1947:01 1990:04 qtr tbill cpu
set infl = log(cpu/cpu{1})*400.0
set rrate = tbill-infl
boxjenk(ar=4,constant) rrate 1960:1 *
@msvarsetup(lags=2,states=3,switch=mh)
# rrate
compute gstart=1960:1,gend=1990:4
frml msvarf = log(%MSVARProb(t))
nonlin(parmset=msparms) theta
nonlin(parmset=varparms) mu phi sigmav
@msvarinitial gstart gend
* Switch around the mu's to match up with the states in the book.
compute temp=mu(3),mu(3)=mu(1),mu(1)=temp
* Estimate the model by maximum likelihood. This effectively converges,
* but because some of the theta's are very large negative (producing
* transition  probabilities which are nearly zero), the convergence
* tests fail because the transition probabilities are extremely flat in
* that neighborhood.
maximize(parmset=varparms+msparms,$
  start=%(p=%mslogisticp(theta),pstar=%MSVARInit()),$
  reject=%MSVARInitTransition()==0,$
  pmethod=simplex,piters=5,method=bfgs,iters=300) msvarf gstart gend
* This pegs the two parameters that are pushed to -infinity as large
* fixed negative values.
nonlin(parmset=pegs) theta(1,2)=-50.00 theta(2,3)=-50.00
maximize(parmset=varparms+msparms+pegs,$
In addition, could you please kindly share with us how to get the guess values, such as for means and variances, in MS models?
Thank you and Happy Easter
Re: Question about guess values in MS models
You chopped out the comments that describe that.
All MS models have a "labeling" issue---you can freely reorder the regimes without affecting the likelihood. The guess values from @MSVARInitial order the means from low to high, while K&N use high to low. Neither is guaranteed to produce the result in that order, but most of the time it will work to get the labels the way you want.
There are no good ways to get generic guess values for MS models. For models where only one parameter switches (mean or variance typically), the guess values in the standard RATS procedures estimate the base model without switching and create guesses for the states by moving up and down from the base estimate. That works most of the time, but not always. Of course, if there are multiple parameters switching, there is no generic way to create guess values for the regimes---whatever your plans are, the best fitting regimes can be completely different.
These types of issues are covered in detail as part of the Structural Breaks and Switching course.
