where does RATS save the output from esmooth?
indrani_5
Unread post by indrani_5 »
Can anyone please tell me where do I find the deseasonalised series after running the following
OPEN DATA "E:\phd\research\RATS\seas.xls"
CALENDAR(Q) 1984:1
DATA(FORMAT=XLS,ORG=COLUMNS) 1984:01 2015:04 y d p lp sp hp m2 comm_e comm_ne nltl npa
esmooth(seasonal=multiplicative,estimate,$
smoothed=esmoothed,fitted=fitted) d 1984:01 2015:04
#d
#esmoothed
#fitted
I was expecting it would automatically be saved in my current folder, but it did not happen that way. Am i missing a command?
Re: where does RATS save the output from esmooth?
It doesn't. If you want to save (I assume you mean to a file) you need to do some operation to handle that. See "Getting Data Out" in Section 2.1 of the Introduction. However, I would only recommend doing that if you're planning to use the adjusted data in another program. If you're just using RATS, just leave the ESMOOTH instruction in. That way, you have documented exactly how the series was created.
