Trouble with Kilian(1998) and time TREND
ijt
Unread post by ijt »
I am currently working on a VAR with Kilian(1998) bias-correction on the IRF. The code seemed to work perfectly fine when I estimated the VAR with det CONSTANT. However, two of my variables present a linear time trend, so I constructed a "TREND = t" variable. But when using DET CONSTANT TREND, the following error appear:
## MAT2. Matrices with Dimensions 14 x 3 and 13 x 3 Involved in + Operation
The Error Occurred At Location 341, Line 33 of KILIANBOOTSETUP
I looked up the killianbootsetup and varbootsetup programs themselves, but could not figure out what is going on. I would extremely aprecciate some help on this issue.
Thank you very much!
Below is my code:
CALENDAR(Q) 1996:1
DATA(FORMAT=WF1) 1996:01 2015:04 C01 CONFIANCAS___NAO_USEI_ES EXPECT_INFL_ FBKF IBGE_DESSAZ_PIB ICC_FGV $
 ICEA_FECOM ICI_FGV IEC_FECOM IPCA_INDICE IPCA_INDICE_SA IPCA_QOQ__A_ IPCA_QOQ_SA IPCA_QOQ_SA_ANN JURO_REAL $
 MEDIA_SELIC RESID
set TREND = t
set L_CONS = log(C01)
set L_PIB = log(IBGE_DESSAZ_PIB)
set L_IEC = log(IEC_FECOM)
SYSTEM(Model=VAR_TRIVARIADO)
VARIABLES L_IEC L_CONS L_PIB
LAGS 1 TO 4
DET Constant TREND
END(SYSTEM)
ESTIMATE(outsigma=varcov)
eigen(cvalues=cv) %modelcompanion(VAR_TRIVARIADO)
disp %cabs(cv(1))
compute nsteps=40
compute ndraws=1000
compute nshocks=1
estimate(resids=resids)
compute nvar=%nvar
compute rstart=%regstart(),rend=%regend()
@KilianBootSetup(model=VAR_TRIVARIADO,resids=resids) rstart rend
declare vect[rect] %%responses(ndraws)
infobox(action=define,lower=1,upper=ndraws,progress) $
   "Second stage bootstrap"
do draw=1,ndraws
   @KilianBootDraw(resids=resids) rstart rend
   impulse(model=%%VARReModel,shocks=%unitv(nvar,1),steps=nsteps,factor=varcov*inv(%diag(%sqrt(%xdiag(varcov)))),$
      flatten=%%responses(draw),noprint)
/*   impulse(model=%%VARReModel,shocks=%unitv(nvar,1),steps=nsteps,$
      flatten=%%responses(draw),noprint)*/
   infobox(current=draw)
end do draw
infobox(action=remove)
@MCProcessIRF(percentiles=||.05,.95||,lower=klower,upper=kupper,$
   irf=kmedian,model=%%VARReModel)
spgraph(hfields=3,footer="Bootstrapped Responses to unit shock in IEC")
 graph(number=0,header="CONSUMO") 3
 # kmedian(2,1)
 # klower(2,1) / 2
 # kupper(2,1) / 2
 graph(number=0,header="PIB") 3
 # kmedian(3,1)
 # klower(3,1) / 2
 # kupper(3,1) / 2
 graph(number=0,header="IEC") 3
 # kmedian(1,1)
 # klower(1,1) / 2
 # kupper(1,1) / 2
Re: Trouble with Kilian(1998) and time TREND
We've posted a revised version of VARBOOTSETUP which can handle different deterministic variables. If you have RATS 8.3 or later, you can use the Update Procedures operation to replace what you currently have.
Reason: (Edited to cite new version)
Last bumped by TomDoan on Mon Jul 25, 2016 6:12 pm.
