MS Regression Time Varying TP Overwriting the Transition Mat
Jules89
Unread post by Jules89 »
Hello Tom,
I am quiet new on RATS and have to estimate a TVTP MS model of the following form:
Number of states: 2
deurchf=a_t +e_t, e_t~N(0, sigma^2_t)
deurchf is the first difference of the exchange rate, a_t is an intercept which is switching between state 1 and state 2. The variance sigma^2 is also switching between state 1 and state 1.
My FTP code is the following:
@MSREGRESSION(States=2, Switch=CH) DEURCHF
# Constant
nonlin(parmset=regparms) betas sigsqv gammas
nonlin(parmset=msparms) p
compute gstart=2011:09:06,gend=2015:12:15
@MSRegInitial gstart gend
compute sigmalimit=1.e-6*%minvalue(sigsqv)
frml logl = f=%MSRegFVec(t),fpt=%MSProb(t,f),log(fpt)
@MSFilterInit
maximize(start=%(sigmatest=%MSRegInitVariances(),pstar=%msinit()),$
parmset=regparms+msparms,$
reject=sigmatest<sigmalimit,$
method=bfgs) logl gstart gend
Now I have the following variable for the TVTP: drreur1m
I tryed to use the code and suggestions of the following post: https://estima.com/forum/viewtopic.php? ... vtp#p11162
Here is the TVTP code I wrote:
source msregression.src
# Constant
nonlin(parmset=tvtpparms) d10 d11 d20 d21
*************Overwiting the Transition Matrix:**************
frml pfrml = %cdf(d10+d11*drreur1m)
frml qfrml = %cdf(d20+d21*drreur1m)
function %MSRegPMat time
type rect %MSRegPmat
type int time
compute %MSRegPMat=||pfrml(time),1-qfrml(time)|1-pfrml(time),qfrml(time)||
*Guess values for the first iteration drawn from the FTP Model:
compute d10 = 1.845
compute d20 = -1.21
compute gstart = 2011:09:06
compute gend = 2015:12:15
frml logl = fpt=%MSRegProb(t),log(fpt)
@MSFilterInit
  parmset=regparms+tvtpparms,$
  method=bfgs,pmethod=simplex,piters=5) logl gstart gend
The estimates are the following:
MAXIMIZE - Estimation by BFGS
Convergence in    14 Iterations. Final criterion was  0.0000085 <=  0.0000100
Daily(5) Data From 2011:09:07 To 2015:12:15
Usable Observations                      1115
Function Value                      4806.6321
1.  BETAS(1)(1)                  -0.000206005  0.000050549     -4.07534  0.00004595
2.  BETAS(2)(1)                   0.000107612  0.000459697      0.23409  0.81491235
3.  SIGSQV(1)                     0.000001883  0.000000171     10.98407  0.00000000
4.  SIGSQV(2)                     0.000121085  0.000010378     11.66757  0.00000000
5.  D10                              1.845000000  0.000000000      0.00000  0.00000000
6.  D11                              0.000000000  0.000000000      0.00000  0.00000000
7.  D20                             -1.210000000  0.000000000      0.00000  0.00000000
8.  D21                              0.000000000  0.000000000      0.00000  0.00000000
What did I do wrong? Could you send me any example code which is doing tvtp estimates and which is simple? I tryed to read the Filardo(1994) replication code, but it is very complicated for someone who is new to RATS.
Thank you very much for your help!
Best
Jules
Re: MS Regression Time Varying TP Overwriting the Transition
Please post the whole program (not just two pieces) and the data set. I really can't tell without seeing how it runs.
Jules89
thank you for the quick reply and sorry for not posting the whole code/data. Here it is:
CALENDAR(D) 2011:9:6
*Data:
OPEN DATA "C:\Users\Jules\Desktop\DataRats.xlsx"
CALENDAR(D) 2011:09:06
DATA(FORMAT=XLSX,NOLABELS,ORG=COLUMNS,TOP=2) 2011:09:06 2015:12:15 RR1M EXRATE
*--------------------- Differences ---------------------*
diff rr1m / drr1m
diff EXRATE / DEXRATE
*--------------------- Markov Switching Without TVTP ---------------------*
@MSREGRESSION(States=2, Switch=CH) DEXRATE
# Constant
@MSFilterInit
*--------------------- Markov Switching With TVTP ---------------------*
# Constant
frml pfrml = %cdf(d10+d11*drr1m)
frml qfrml = %cdf(d20+d21*drr1m)
type int time
compute d10 = 1.845
compute d20 = -1.21
@MSFilterInit
DataRats.xlsx
And here are the data
(88.06 KiB) Downloaded 839 times
You didn't give guess values to the two "slope" coefficients in the TVTP function (though those are assumed 0, which is probably the best guess anyway). However, the problem is that you need a newer version of msregression.src.
msregression.src
(16.63 KiB) Downloaded 956 times
Jules89
Hey Tom,
thank you so much for your help! It works. Is there a possibility to do this regression also in the MSVARSetup enviroment? So my question ist whether it is possible to overwrite the transition matrix in this way for any of the MSxxxx(VAR,SYS, etc) procedures?
Do I also need newer Versions of the procedures?
Thank you again so much for your help! You saved my day
Best
Jules
Jules89
Hey Tom,
in the post before I meant something like the following code, which should estimate something similar as the one above by using the @MSVARSetup:
*Data:
diff rr1m / drr1m
source msvarsetup.src
@MSVARSetup(lags=0 ,States=2, Switch=IH)
# DEXRATE
nonlin(parmset=regparms) mu phi sigmav
compute d10 = 1.845
compute d20 = -1.21
compute d11 = 0.0
compute d21 = 0.0
function %MSVARPMat t
type rect %MSVARPmat
type int t
compute %MSVARPMat=||pfrml(t),1-qfrml(t)|1-pfrml(t),qfrml(t)||
@msvarinitial gstart gend
frml logl = fpt=%MSVARProb(t),log(fpt)
maximize(parmset=regparms+tvtpparms,$
         start=(pstar=%MSVARInit()),$
         reject=%MSVARInitTransition()==0.0,$
         method=bfgs) logl
The same problem as before comes up. Here is the output:
Convergence in    22 Iterations. Final criterion was  0.0000064 <=  0.0000100
Function Value                      4806.5584
1.  MU(1)(1)                      0.000273941  0.000289383      0.94664  0.34382355
2.  MU(2)(1)                     -0.000207977  0.000044048     -4.72165  0.00000234
3.  SIGMAV(1)(1,1)             0.000120321  0.000009950     12.09276  0.00000000
4.  SIGMAV(2)(1,1)             0.000001922  0.000000119     16.14361  0.00000000
It would be very nice if you could also have a look at that. The data are the same as before.
Thank you very much in advance, I really appreciate your help.
Best
Jules
