Convergence issue in DCC GARCH
Vik_pa
Unread post by Vik_pa »
I am trying to estimate my model using bivariate BEKK GARCH and DCC GARCH. I have using weekly data for 15 years. For DCC GARCH model, I am facing the No Convergence issue when using the ar1/var model in the mean equation. With out the var model in the mean equation and with mean equation containing the constant only, it converge in 32 iterations. Also for BEKK model there is no issue in convergence with var model as mean equation.
Can you please help me in this issue.
Kind Regards,
My code for BEKK is
system(model=var1)
var Crude_return Gold_return
lags 1
garch(model=var1, p=1,q=1,mv=bekk,rseries=rs,mvhseries=hs,stdresids=z,derives=d) / crude_return gold_return
DCC GARCH Code
GARCH(MODEL=VAR1,P=1,Q=1,MV=DCC,METHOD=BHHH,PMETHOD=SIMPLEX,PITERS=10) / CRUDE_RETURN GOLD_RETURN
Re: Convergence issue in DCC GARCH
That's probably a good indication that DCC is a bad choice.
