I have rewriten the replication code for the Filardo (1994) paper, because I wanted to estimate the model by maximum likelihood.
This is my Code:
************************* Reading in and Transforming the Data *************************
cal(m) 1948
open data filardo.dat
data(format=prn,org=cols) 1948:1 1992:8 year month ip cli dfi xli sp fed tspread
set ipgr = 100.0*log(ip/ip{1})
stats(noprint) ipgr * 1959:12
compute stdearly=sqrt(%variance)
stats(noprint) ipgr 1960:1 *
compute stdlate=sqrt(%variance)
set ipgradjust = %if(t<=1959:12,ipgr*stdlate/stdearly,ipgr)
set g = ipgradjust
set cligr = 100.0*log(cli/cli{1})
set spgr = 100.0*log(sp/sp{1})
set xlidiff = xli-xli{1}
set ffdiff = fed-fed{1}
set tspdiff = tspread-tspread{1}
set dfismooth = dfi+2*dfi{1}+2*dfi{2}+dfi{3}
* Center variabes to zero means
dofor s = cligr spgr xlidiff ffdiff tspdiff dfismooth
diff(center) s
end dofor s
**************************** Setting up the Markov Switching ****************************
source msvarsetup.src
compute nlags=4
compute gstart=1948:6,gend=1992:8
@MSVARSetup(lags=nlags, Switch=M)
# g
nonlin(parmset=common) mu phi sigmav
******************** Time varying probabilities **********************
dec equation p1eq p2eq
dec vector v1 v2
nonlin(parmset=tv) v1 v2
********** Overwriting the standard fixed transition matrix **********
function %MSVARPmat time
type rect %MSVARPmat
type int time
local integer i j
local rect pexpand
local real z
compute p(1,1)=%(z=exp(%dot(%eqnxvector(p1eq,time),v1)),z/(1+z))
compute p(1,2)=%(z=exp(%dot(%eqnxvector(p2eq,time),v2)),1/(1+z))
compute %MSVARInitTransition()
if nexpand==nstates {
dim pexpand(nstates,nstates-1)
ewise pexpand(i,j)=%if(i==nstates,-1.0,i==j)
compute %MSVARPmat=pexpand*p
ewise %MSVARPmat(i,j)=%if(i==nstates,1.0+%MSVARPmat(i,j),%MSVARPmat(i,j))
else {
dim %MSVARPmat(nexpand,nexpand)
ewise %MSVARPmat(i,j)=MSVARTransProbs(MSVARTransLookup(i,j))
******* Initialize the probabilities using only the intercepts *******
function TVPInit
type vector TVPInit
local rect a
local integer i j
compute p=||%logistic(v1(1),1.0),1-%logistic(v2(1),1.0)||
compute TVPInit=%MSVARInit()
********************* Calculating the Likelihood *********************
frml logltvtp = %MSVARPMat(t),log(%MSVarProb(t))
****************** Initialize the other Parameters *******************
@MSVARInitial
*** Define the logistic index for the transitions
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
***Starting Values
compute v1=log(.7/.3)~~0.0
compute v2=log(.95/.05)~~0.0
compute mu(1)=-1.7,mu(2)=.3
**************** Maximization of the Log-Likelihood *****************
maximize(parmset=tv+common,start=(pstar=TVPInit()),$
method=bfgs) logltvtp gstart gend
My first question is: Is the code right or are there any mistakes? I checked the results and they are close to the Filardo Paper.
My second question is: Where do the guess values for v1 and v2 come from? I do not understand why the first elements of the two vectors are set equal to log(0.7/0.3) and log(0.95/0.05). Is there any general method for deriving the guess values or can these values be used for any markov switching VAR model?
Thank you in advance
Jules
