I want to estimate an Hamilton Style MS-AR(1) with TVTP by using EM. Therefore I used the replication code of FIlardo(1994). The Filardo code I use is the following:
************************* Reading in and Transforming the Data *************************
cal(m) 1948
open data filardo.dat
data(format=prn,org=cols) 1948:1 1992:8 year month ip cli dfi xli sp fed tspread
set ipgr = 100.0*log(ip/ip{1})
stats(noprint) ipgr * 1959:12
compute stdearly=sqrt(%variance)
stats(noprint) ipgr 1960:1 *
compute stdlate=sqrt(%variance)
set ipgradjust = %if(t<=1959:12,ipgr*stdlate/stdearly,ipgr)
set g = ipgradjust
set cligr = 100.0*log(cli/cli{1})
set spgr = 100.0*log(sp/sp{1})
set xlidiff = xli-xli{1}
set ffdiff = fed-fed{1}
set tspdiff = tspread-tspread{1}
set dfismooth = dfi+2*dfi{1}+2*dfi{2}+dfi{3}
* Center variabes to zero means
dofor s = cligr spgr xlidiff ffdiff tspdiff dfismooth
diff(center) s
end dofor s
**************************** Setting up the Markov Switching CTP ****************************
source msvarsetup.src
compute nlags=1
compute gstart=1948:06,gend=1992:8
@MSVARSetup(lags=nlags)
# g
nonlin(parmset=common) mu phi sigma
nonlin(parmset=fixed) p
frml loglftp = log(%MSVarProb(t))
@MSVARInitial gstart gend
**************************** Setting up the EM-Algorithm ****************************
@msvarEMgeneralsetup
*** Inserting Guess Values
compute mu(1)=-1.7,mu(2)=.3
compute p(1,1)=.3,p(1,2)=.1
@msvartestvector(dop,domu,dovar) baseparms
do emits=1,100
@msvaremstep gstart gend
@msvartestvector(dop,domu,dovar) testparms
compute %cvcrit=%testdiff(baseparms,testparms)
if %cvcrit<.0001
break
compute baseparms=testparms
disp "Iteration" emits "Log Likelihood" %logl %cvcrit
end do emits
**************************** Maximization CTP ****************************
maximize(start=(pstar=%MSVARInit()),parmset=fixed+common,$
method=bhhh,iters=20) loglftp gstart gend
******************** Time varying probabilities **********************
dec equation p1eq p2eq
dec vector v1 v2
nonlin(parmset=tv) v1 v2
********** Overwriting the standard fixed transition matrix **********
function %MSVARPmat time
type rect %MSVARPmat
type int time
local integer i j
local rect pexpand
local real z
compute p(1,1)=%(z=exp(%dot(%eqnxvector(p1eq,time),v1)),z/(1+z))
compute p(1,2)=%(z=exp(%dot(%eqnxvector(p2eq,time),v2)),1/(1+z))
compute %MSVARInitTransition()
if nexpand==nstates {
dim pexpand(nstates,nstates-1)
ewise pexpand(i,j)=%if(i==nstates,-1.0,i==j)
compute %MSVARPmat=pexpand*p
ewise %MSVARPmat(i,j)=%if(i==nstates,1.0+%MSVARPmat(i,j),%MSVARPmat(i,j))
else {
dim %MSVARPmat(nexpand,nexpand)
ewise %MSVARPmat(i,j)=MSVARTransProbs(MSVARTransLookup(i,j))
******* Initialize the probabilities using only the intercepts *******
function TVPInit
type vector TVPInit
local rect a
local integer i j
compute p=||%logistic(v1(1),1.0),1-%logistic(v2(1),1.0)||
compute TVPInit=%MSVARInit()
***** Controlling routine for EM estimation of time-varying probabilities *****
procedure MSVARTVPEMEstimate start end
type integer start end
option integer iters 100
option real cvcrit 1.e-6
local integer emits time k
local series l11 l22 w11 w22
local vector baseparms testparms
local rect thisEntry
@msvartestvector(domu,dovar) baseparms
compute baseparms=baseparms~~v1~~v2
do emits=1,iters
compute %eqnsetcoeffs(p1eq,v1)
compute %eqnsetcoeffs(p2eq,v2)
@msvarestep start end
compute %emlogl=%logl
@msvarmstep(nodop) start end
* Compute the weights and dependent variable for the one-step
* correction on the logistics.
set l11 start end = 0.0
set l22 start end = 0.0
set w11 start end = 0.0
set w22 start end = 0.0
do time=start,end
compute %MSVARPMat(time)
compute thisEntry=%zeros(nstates,nstates)
do k=1,MSVARFilterSize
compute thisEntry(MSVARLagState(k,1),MSVARLagState(k,2))+=MSVARPTSM(time)(k)
end do k
compute w11(time)=p(1,1)*(1-p(1,1))*(thisEntry(1,1)+thisEntry(2,1))
compute w22(time)=p(1,2)*(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2))
compute l11(time)=(thisEntry(1,1)- p(1,1)*(thisEntry(1,1)+thisEntry(2,1)))/w11(time)
compute l22(time)=(thisEntry(2,2)-(1-p(1,2))*(thisEntry(2,2)+thisEntry(1,2)))/w22(time)
end do time
* Update the coefficients
linreg(noprint,weight=w11,equation=p1eq) l11 start end
compute v1=v1+%beta
linreg(noprint,weight=w22,equation=p2eq) l22 start end
compute v2=v2+%beta
* Check for convergence
@msvartestvector(domu,dovar) testparms
compute testparms=testparms~~v1~~v2
if %cvcrit<cvcrit
break
disp "Iteration" emits "Log Likelihood" %emlogl %cvcrit
end do emits
end MSVARTVPEMEstimate
********************* Calculating the Likelihood *********************
frml logltvtp = %MSVARPMat(t),log(%MSVarProb(t))
****************** Initialize the other Parameters *******************
equation p1eq *
# constant cligr{1}
equation p2eq *
# constant cligr{1}
compute v1=log(.7/.3)~~0.0
compute v2=log(.95/.05)~~0.0
@MSVARTVPEMEstimate(cvcrit=.0001) gstart gend
maximize(parmset=tv+common,start=(pstar=TVPInit()),$
method=bhhh) logltvtp gstart gend
********************* Various other combinations *********************
equation p1eq *
# constant cligr{1 2}
equation p2eq *
compute v1=v1~~0.0
compute v2=v2~~0.0
equation p1eq *
# constant xli{1}
equation p2eq *
# constant xli{1}
compute mu(1)=-1.7,mu(2)=.33
method=bhhh,iters=20) logltvtp gstart gend
equation p1eq *
# constant xli{1 2}
equation p2eq *
# constant xli{1 2}
compute v1=log(.7/.3)~~0.0~~0.0
compute v2=log(.95/.05)~~0.0~~0.0
equation p1eq *
# constant spgr{1}
equation p2eq *
# constant spgr{1}
equation p1eq *
# constant ffdiff{1}
equation p2eq *
equation p1eq *
# constant tspdiff{1 2}
equation p2eq *
(Its basicly the Filardo code with switching mean and varaince and other data)
*********** Reading in Data and Renaming Them ***********
OPEN DATA "my directory"
CALENDAR(D) 2013:01:01
DATA(FORMAT=XLSX,ORG=COLUMNS) 2013:01:01 2015:12:15 skew s
compute nlags=1
compute gstart=2013:01:01
compute gend=2015:12:15
display gstart
display gend
@MSVARSetup(lags=nlags,switch=mh)
# s
nonlin(parmset=common) mu phi sigmav
do emits=1,100
if %cvcrit<.00001
break
end do emits
method=bhhh) loglftp gstart gend
dec vector v1 v2
type int time
local integer i j
local rect pexpand
local real z
else {
function TVPInit
type vector TVPInit
local rect a
local integer i j
do emits=1,iters
do time=start,end
end do k
end do time
compute v1=v1+%beta
compute v2=v2+%beta
if %cvcrit<cvcrit
break
end do emits
equation p1eq *
# constant skew{1}
equation p2eq *
# constant skew{1}
compute v1=log(0.95/(1-0.95))~~0.0
compute v2=log(0.95/(1-0.95))~~0.0
@MSVARTVPEMEstimate(cvcrit=.000001) gstart gend
1) When I start
do emits=1,100
if %cvcrit<.00001
break
end do emits
## NL6. NONLIN Parameter P(1,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter P(1,2) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter MU(1)(1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter MU(2)(1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter PHI(1)(1,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter SIGMAV(1)(1,1) Has Not Been Initialized. Trying 0
## NL6. NONLIN Parameter SIGMAV(2)(1,1) Has Not Been Initialized. Trying 0
The Error Occurred At Location 961, Line 41 of MSVARTVPEMESTIMA
35445160 Position 3539
Can you please have a look at all those codes and tell me what I did wrong? I am lost in the forest^^
The data are attached .
Thank you very much in advance
