Montevar using ffunction question
tomemmerling
Unread post by tomemmerling »
I'm trying to obtain confidence bounds for my impulse response graphs for a VAR using an alternative factorization for the G matrix (i.e., not Cholesky). I'm not sure what I'm doing wrong below in order to produce the graphs. I tried to create a function with the required type which returns the rectangular G matrix. However, I get an error saying otherwise--see below. I'm sure the problem is obvious but I really appreciate your help! Note I compute the covariance matrix "v" and define "model1" using the system command prior to the following code.
* ffunction definition
function myfcn vv model
type rectangular myfcn
type symmetric vv
type model model
nonlin g11 g12 g13 g15 g22 g23 g24 g31 g33 g34 g41 g44 g52 g53 g55
dec frml[rect] g_form
frml g_form = || g11, g12, g13, 0, g15| 0, g22, g23, g24, 0 | g31, 0, g33, g34, 0 | g41, 0, 0, g44,0 |0, g52 , g53 , 0, g55 ||
com g11 = vv(1,1), g12 = vv(1,2), g13 = vv(1,3), g15=vv(1,5), g22 = vv(2,2), g23=vv(2,3),g24=vv(2,4)
com g31 = vv(3,1), g33 = vv(3,3),g34=vv(3,4), g41=vv(4,1), g44 = vv(4,4), g52 = vv(5,2), g53 = vv(5,3),g55=vv(5,5)
cvmodel(factor=z,noprint) vv g_form
compute myfcn=z
disp myfcn(v,model1)
* call montevar with v and model1
@montevar(model=model1,steps=13,header="IRF's with Error Bands",ffunction=myfcn(v,model1))
## SX22. Expected Type FUNCTION(SYMMETRIC[REAL],MODEL)-->RECTANGULAR[REAL], Got RECTANGULAR[REAL] Instead
>>>>on=myfcn(v,model1))<<<<
Re: Montevar using ffunction question
If would just be
@montevar(model=model1,steps=13,header="IRF's with Error Bands",ffunction=myfcn)
However, your model fails the Rubio-Ramirez-Waggoner-Zha identification rules.
