PANEL VAR
power23
PANEL VAR
Unread post by power23 »
I am looking for any available code to estimate a model using a Panel VAR in RATS
Thanks!
Re: PANEL VAR
That's not really a well-defined technique---it depends on the structure of the data set and what assumptions you want to make. See the discussion in the thread https://estima.com/forum/viewtopic.php? ... 803&p=3741. The thread https://estima.com/forum/viewtopic.php? ... 765#p13036 is about a completely different approach of a "shrinkage" estimator which can be used when your data set is large in the time dimension and you want to assume the VAR dynamics are are "similar" but not identical.
kalaba
Re: PANEL VAR
Unread post by kalaba »
Hello, i want to estimate a panel structural VAR like one in Pedroni (2013).
If someone have the Rats code , please share that with me
