Gibbs Minnesota VAR, structural residuals
Jules89
Unread post by Jules89 »
I am using the following code to estimate a GIBBS VAR with a Minnesota Prior and do impulse response analysis, where the identification comes from a Cholesky Decomposition:
*** Data
open data haversample.rat
cal(q) 1959
data(format=rats) 1959:1 2006:4 ftb3 gdph ih cbhm
set loggdp = log(gdph)
set loginv = log(ih)
set logc   = log(cbhm)
*** VAR Setup and Storage Matrices
compute lags=4			;*Number of lags
compute nstep=40		;*Number of response steps
compute nburn=500   	;*Number of burn-in draws
compute ndraws=2500	    ;*Number of keeper draws
compute tight=.1
compute other=.5
system(model=varmodel)
   variables loggdp loginv logc ftb3
   lags 1 to lags
estimate(ols,sigma)  ;*initial set of estimations
impulse(noprint,model=varmodel,steps=nstep,results=impulses)  ;*initial set of of impulse responses
display %cmom
compute nvar=%nvar
dec vect olssee(nvar)
ewise olssee(i)=sqrt(%sigma(i,i))
declare vect[rect] %%responses(ndraws)
*** Minnesota Prior using @BVARBuildPriorMN
source BVARBuildPriorMN.src
@BVARBuildPriorMN(model=varmodel,tight=tight,other=other) HBPRIORS HPRIORS
@BVARFinishPrior hbpriors hpriors bprior hprior
compute sigmad=%sigma
cmom(model=varmodel)
display hprior
display bprior
*** GIBBS Sampling Loop
infobox(action=define,progress,lower=-nburn,upper=ndraws) "Gibbs Sampler"
do draw=-nburn,ndraws
   infobox(current=draw)
   * Draw b given sigma
   compute bdraw =%ranmvkroncmom(%cmom,inv(sigmad),hprior,bprior)
   compute rssmat=%sigmacmom(%cmom,bdraw)
   * Draw sigma given b
   compute sigmad=%ranwisharti(%decomp(inv(rssmat)),%nobs)
   if draw<=0
      next
   compute %modelsetcoeffs(varmodel,bdraw)
   impulse(noprint,model=varmodel,results=impulses,steps=nstep)
   * Store the impulse responses
   dim %%responses(draw)(nvar*nvar,nstep)
   local vector ix
end do draw
infobox(action=remove)
*** Impulse Response
@mcgraphirf(model=varmodel,center=median,percentiles=||.10,.90||)
What I want to do now is to calculate for every draw within the Gibbs sampler the identified structural residuals. How would I do that?
Best
jules
Re: Gibbs Minnesota VAR, structural residuals
This will compute the VAR residuals (into the VECT[SERIES] U)
forecast(model=varmodel,from=hstart,to=hend,errors=u,static)
where HSTART and HEND is the original estimation range (looks like %REGSTART() and %REGEND() will work for those). You can transform those into the Cholesky residuals using @StructResids.
