IRF for STAR models
Javi
IRF for STAR models
Unread post by Javi »
Dear Rats users:
I am looking for a code to estimate IRF for STAR models. Is there anybody who has a code to estimate it?
Thanks in advance.
Best regards,
Re: IRF for STAR models
Because of the non-linearities, STAR models don't really have an IRF like a VAR does; the response to a shock depends on the
current value and doesn't scale up linearly. The "eventual forecasting function" is commonly used to give some idea of the
long-term behavior. An example of that is in the Terasvirta 1994 replication file LYNX.PRG.
If you want something closer to an actual IRF, you can do the eventual forecast as shown in that example, then repeat with a
SHOCKS option on the FORECAST. The difference between the two would be the analog of an IRF. Note, however, that this can be quite sensitive to the size of the shock, that is, (unlike linear models) the response to a "1.0" shock won't be half the response to a "2.0" shock.
This adds the calculation of the responses to shocks of size 1.0 and 3.0 to the end of the lynx example. You can see how the behavior is quite far from being scales of each other.
* Example 3 from Terasvirta(1994), "Specification, Estimation and Evaluation of
* Smooth Transition Autoregressive Models", JASA, vol 89, pp 208-218.
cal(a) 1821
open data lynx.dat
data(org=cols) 1821:1 1934:1 lynx
set x = log(lynx)/log(10)
diff(center) x / xc
* The YuleLags procedure does a quick, efficient examination of a range of AR
* models for stationary data.
@yulelags(max=20) x
* The tests shown are done on the demeaned data
source startest.src
do d=1,9
   @StarTest(p=11,d=d) xc
end do d
* This initially fixes the c and gamma at the mean and two times the reciprocal of
* the standard error, respectively. (The logistic exponent is rescaled by 1/sigma
* as shown in the article), so gamma is, with that parameterization, put at 2.
* This gives a fairly sharp split between larger and smaller values, so two
* branches should have decidedly different coefficients if there is evidence of
* STAR. With c and gamma fixed, NLLS is actually just OLS.
stats x
nonlin(parmset=starparms) gamma c
frml flstar = %logistic(1.8*gamma*(x{3}-c),1.0)
compute c=%mean,gamma=2.0
equation standard x
# constant x{1 to 11}
equation transit x
frml(equation=standard,vector=phi1) phi1f
frml(equation=transit ,vector=phi2) phi2f
frml star x = f=flstar,phi1f+f*phi2f
nonlin(parmset=regparms) phi1 phi2
nlls(parmset=regparms,frml=star) x
* Based upon the initial results, the standard equation is trimmed to just x{1}
* and transit to x{2 3 4 10 11} (The article shows lag 9 rather than 10, but this
* specification fits quite a bit better). This is now estimated with all the
* parameters.
equation standard x
# x{1}
equation transit x
# x{2 3 4 10 11}
nlls(parmset=regparms+starparms,frml=star) x
* This will do the model shown in the article
equation standard x
# x{1}
equation transit x
# x{2 3 4 9 11}
stats %resids
* Analysis of roots of the polynomials
associate standard phi1
associate transit  phi2
compute upper=standard+transit
* The equation <<upper>> is created by adding the right hand sides of the standard
* and transit polynomials.
@LagPolyRoots %eqnlagpoly(upper,x)
@LagPolyRoots %eqnlagpoly(standard,x)
* Compute eventual forecasting function
group starmodel star>>sforecast
forecast(model=starmodel,steps=100,from=1935:1)
graph 2
# sforecast
# x 1920:1 1934:1
set base 1935:1 1935:1+99 = sforecast
forecast(model=starmodel,steps=100,from=1935:1,shocks=1.0)
set irf1 1935:1 1935:1+99 = sforecast-base
forecast(model=starmodel,steps=100,from=1935:1,shocks=3.0)
set irf3 1935:1 1935:1+99 = sforecast-base
graph(header="Responses to shocks",key=upright,klabels=||"1.0 Shock","3.0 Shock"||) 2
# irf1
# irf3
luxu1983
Unread post by luxu1983 »
what do the shocks stand for? can stand for standard deviation
No. That's 1.0 and 3.0. If you want one standard deviation, use SHOCKS=||sqrt(%seesq)||.
luxu1983
dear sir
can this method (using forcecast)calculateing the irf extend to multivariable nonlinear model ? :) :D :?:
It's not "the IRF", but yes.
luxu1983
TomDoan wrote:It's not "the IRF", but yes.
dear tom
can i call it GIRF?
i find G Koop, MH Pesaran, and SM Potter(1996) extend linear irf to the nonlinear case by defining a generalized impulse response function that is very similar to your method
but in their method includes " simulation"
may you provide the example that is nonlinear case using the generalized impulse response function ? :D
What they're doing is taking the base forecast, then, instead of doing one shock of a certain size and taking the difference as an estimate of an IRF, they do one shock and then draw a realization of the error process beyond that and average. Since
  1. the average isn't necessarily a good measure of central tendency in a highly non-linear function,
  2. the average depends upon the distribution from which the other shocks are drawn,
  3. the results are dependent upon the initial values
the whole thing still makes little sense. If you want to pursue it, read chapter 13 of the User's Guide, particularly sections 13.1 and 13.2. Those will explain how to get the averages. A single draw would be done with something like:
set shocks 1935:1 1935:1+99 = %if(t==1935:1,delta,%ran(mystddev))
forecast(model=starmodel,steps=100,from=1935:1,paths)
# shocks
where delta is the initial shock and mystddev is the (mean zero) standard deviation for the Normal density for the future shocks.
luxu1983
dear Tom
thank you very very much
i modify it follow you suggestion adding shocks
but it doesn't work well
set shocks = %if(t==1935:1,0.1,%ran(1))
forecast(model=starmodel,steps=100,from=1935:1,path)
# shocks
graph(header="Responses to shocks",key=upright)
# irf1
luxu1983 wrote:dear Tom
# shocks
# irf1
Sorry. The set shocks should have read
set shocks 1935:1 1935:1+99 = %if(t==1935:1,0.1,%ran(1))
I've also corrected that in the original post. However, %ran(1) is way out of bounds for this series. As I mentioned in point 2 above, the average across draws will depend upon the distribution you use there. When you consistently hit the process with shocks which are something like six standard deviations, you don't know what's going to happen.
guo
Unread post by guo »
Thank you so much for your previous advice and I really appreciate your suggestions.
I am doing ESTAR model, and I want to get nonlinear "IRF" in my analysis.
equation standard dlEX_CA
# Constant dlneer{4 8 12} dlppi{3 10 11} dlEX_CA{1 2 3 4 12}
equation transit dlEX_CA
# Constant dlneer{0 8 12} dlppi{1 2 5 6 7} dlEX_CA{1 2 3 4 9}
nlls(parmset=regparms,frml=star) dlEX_CA
nlls(parmset=regparms+starparms,frml=star) dlEX_CA
stats %resids
@LagPolyRoots %eqnlagpoly(upper,dlEX_CA)
@LagPolyRoots %eqnlagpoly(standard,dlEX_CA)
forecast(model=starmodel,steps=100,from=2012:4)
graph 2
# sforecast
# dlEX_CA 2003:1 2012:3
set base 2012:4 2012:4+99 = sforecast
forecast(model=starmodel,steps=100,from=2012:4,shocks=1.0)
set irf1 2012:4 2012:4+99 = sforecast-base
forecast(model=starmodel,steps=100,from=2012:4,shocks=3.0)
set irf3 2012:4 2012:4+99 = sforecast-base
# irf1
# irf3
However, the error emerges,
## SR14. Empty Range on Series SFORECAST.
## I2. Expected Instruction Here
## SR14. Empty Range on Series IRF1.
Under this circumstance, what should I do to get the "IRF", because I have some exogenous variables (dlneer and dlppi) in the ESTAR model.
Thank you very much for your precious time and attention.
Your help is greatly appreciated.
Kind Regards
guo
Without the complete program and data set, I can't tell much about it.
PedroClavijo
Unread post by PedroClavijo »
in Farooq (2005) "Multiple unemployment equilibria and asymmetric dynamics—Norwegian evidence" (Structural Change and Economic Dynamics) he presents an IRF, which, depending on the size of the shock, converges to one or another equilibrium (If the size of the shock is such that the value of the threshold variable becomes larger than the threshold value) I would like to know how should I modify the IRF we find for Star models in RATS, in order to get something like that.
PC
(I am attaching the paper)
Multiple unemployment equilibria and asymmetric dynamics—Norwegian evidence.pdf
(469.41 KiB) Downloaded 2451 times
In general, a STAR model won't produce that. (Even this probably won't if you let it run long enough).
The typical STAR model produces a stationary process, so there really aren't two "equilibria". There are two branches, but the process moves between the two and the dynamics within each aren't as important as the behavior of the overall model. For instance, it's quite possible for each branch to be (in isolation) explosive as long as each tends to push the process towards the transition to the other. The paper cited comes up with two "equilibria" because it is using the wrong tool. If you look at Figure 1, there's a clear one-time structural break. A STAR model can "explain" that in a rather crude way, but because there is really only one "transition" it makes no real sense to extrapolate the behavior outside the one set of observed data. (Note that because the two branches are widely separated, the only way to move from the high to the low is with a very rapid drop---does anyone believe the unemployment would ever come down that quickly?).
You might want to read the "How to Switch if You Must" article in the January 2018 newsletter. While that's primarily about incorrectly choosing a Markov Switching Model, the same goes for incorrectly choosing a transition model.
PedroClavijo
Dear Tom.
How should I cite a RatsLetter?
PC
