Help with PVAR code
Ozmando
Help with PVAR code
Unread post by Ozmando »
I have adapted this code to run with my data (sorry the code is not fully cleaned). I am trying to get the impulse response graphs to appear one at the time. Also the code seems to print black and white and I would like them in color, please. Any help please?
*************  ESTIMATION OF PVAR FOR 18 COUNTRIES OVER 1970-2008 PERIOD ***********
environment  noecho
calendar(panelobs=39) 1970
allocate 18//2008:1
open data D:\temp\Rats\PVAR\crisis.xls
data(format=xls, org=columns)
COMPUTE LAGS=2				;*Set number of logs
COMPUTE NVAR=5
COMPUTE NSTEP=11
COMPUTE NDRAWS=2000
COMPUTE N = 18				;*Number of countries
compute YYY = 37    		;*Number of observations for each country
compute f1=0.05
compute f2=0.95
compute gg=1				;*Position of Government Spending G
compute tt=2				;*Position of Government Net Taxes NT
compute yy=3				;*Position of Output Y
compute ratiogy=0.241   ;*Average Ratio G/Y
compute rationty=0.217	;*Average Ratio NT/Y
dec vect[strings] ylabel(nvar+2)
compute ylabel(gg)= 'Exp'
compute ylabel(tt)= 'Inv'
compute ylabel(yy)= 'Crisis'
compute ylabel(4)= 'Tax '
compute ylabel(5)= 'Debt'
compute ylabel(6)= 'Budget'
*  this created country specific dummies and linear trend
SET LTREND = %PERIOD(T)
dec vector[series] dummies(N) time(YYY) trend(N) qtrend(N)
do i=1,N
	set dummies(i) = %indiv(t)==i
	set trend(i)    = (%indiv(t)==i)*ltrend
	set qtrend(i)    = (%indiv(t)==i)*ltrend*ltrend
* time dummy
do i=1,YYY
set time(i)    = (%period(t)==i)
*print / time
*	ggflq{1}ggflq{2}
* !!!!!!!!!   change specification of the VAR !!!!!!!!!!!!!!!!!!!!!
system(model=varmodel)
variables g ntc y irl reer
lags 1 to lags
kfset xxx
det    dummies time
estimate(noprint,outsigma=vmat,RESIDUALS=RESVAR)
*set gshock = resvar(1)
* print / resvar
*  The nonlinear parameters are put into a vector. This is not the
*  most convenient way to code this for estimation (as it's harder
*  to adjust the model), but it considerably cleans up the process
*  of making draws.
*  nfree is the number of free coefficients
* !!!!!!!!!   change short-run identifying restrictions !!!!!!!!!!!!!!!!!
compute nfree=10
dec vect ax(nfree)
nonlin ax
dec frml[rect] afrml
frml afrml = 	||	1.0       ,0.0    ,0.0    ,0.0	  ,0.0	  |$
             		-ax(1) 	 ,1.0    ,0.0	  ,0.0 	  ,0.0     |$
                	-ax(10)   ,-ax(3) ,1.0    ,0.0 	  ,0.0     |$
                	-ax(4)    ,-ax(5) ,-ax(6) ,1.0 	  ,0.0     |$
						-ax(7)    ,-ax(8) ,-ax(9) ,-ax(2)  ,1.0     ||
compute ax=%const(0.01)
*cvmodel(iters=20,method=simplex) vmat afrml
cvmodel(iters=300,method=bfgs,noprint) vmat afrml
declare rect sxx swish betaols betadraw
declare symm sigmad
declare rect sxx svtr swish betaols betadraw
declare symm sigmad
compute sxx    =%decomp(xxx)
compute svtr   =tr(%decomp(vmat))
compute ncoef  =%rows(sxx)
compute wishdof=%nobs-ncoef
declare rect ranc(ncoef,nvar)
declare vect[rect] responses(ndraws)
infobox(action=define,progress,lower=1,upper=ndraws) 'Monte Carlo Integration'
do draws = 1,ndraws
   if %clock(draws,2)==1 {
      compute sigmad  =%mqform(%nobs*inv(%ranwishart(nvar,wishdof)),svtr)
      compute swish   =%decomp(sigmad)
		compute ranc    =%ran(1.0)
      compute betau   =sxx*ranc*tr(swish)
   else
   impulse(noprint,model=varmodel,decomp=swish,results=impulses) nvar nstep
   dim responses(draws)(nvar*nvar,nstep)
   ewise responses(draws)(i,j)=impulses((i-1)/nvar+1,%clock(i,nvar))(j)
   infobox(current=draws)
end do draws
infobox(action=remove)
* GRAPH
grparm(italics)  axislabelling 25
grparm(nobold,italics) matrixlabelling 30
grparm  header 30
spgraph(xpos=upper,vfields=3,hfields=2)
dec vect[series] upper(nvar) lower(nvar) resp(nvar)
smpl 1 ndraws
clear resp(gg)
do k=1,nstep
set work   1 ndraws = responses(t)((gg-1)*nvar+gg,k)
compute frac=%fractiles(work,||f1,f2||)
compute resp(gg)(k)=%avg(work)
end do k
compute ggg=resp(gg)(1)
do i=1,nvar
   compute minlower=maxupper=0.0
   smpl 1 ndraws
   clear lower(gg) upper(gg) resp(gg)
      do k=1,nstep
         set work   1 ndraws = responses(t)((i-1)*nvar+gg,k)
*print(nodates) / work
         compute lower(gg)(k)=frac(1)/(ggg*ratiogy)
         compute upper(gg)(k)=frac(2)/(ggg*ratiogy)
         compute resp(gg)(k)=%avg(work)/(ggg*ratiogy)
end do k
compute maxupper=%max(maxupper,%maxvalue(upper(gg)))
compute minlower=%min(minlower,%minvalue(lower(gg)))
	smpl 1 nstep
display ylabel(i)
print / resp(gg) upper(gg) lower(gg)
	graph(ticks,vticks=5,patterns,min=minlower,max=maxupper,number=0,samesize,picture='*.#',hlabel='years after shock',header=''+ylabel(i)) 3
		# resp(gg) / 1
      # upper(gg) / 6
      # lower(gg) / 6
do i=6,6
   smpl 1 ndraws
      do k=1,nstep
         set work   1 ndraws = -ratiogy*responses(t)((gg-1)*nvar+gg,k)+rationty*(responses(t)((tt-1)*nvar+gg,k)+2.1*responses(t)((yy-1)*nvar+gg,k))-(ratiogy-rationty)*responses(t)((yy-1)*nvar+gg,k)
      end do k
	smpl 1 nstep
display ylabel(i)
		# resp(gg) / 1
      # upper(gg) / 6
      # lower(gg) / 6
clear all
crisis.xls
(78 KiB) Downloaded 750 times
Re: Help with PVAR code
Aren't your upper and lower bounds coming out in color? And what does "print" mean? An actual physical printer needs to be set to print in color; if you set if for gray scale, it will come out black and white.
Ozmando
TomDoan wrote:Aren't your upper and lower bounds coming out in color? And what does "print" mean? An actual physical printer needs to be set to print in color; if you set if for gray scale, it will come out black and white.
The actual output is black and white. for some reasons
output.RGF
(3.31 KiB) Downloaded 989 times
You used the PATTERNS option, which tells it to do the graphs in B&W.
Ozmando
TomDoan wrote:graph(ticks,vticks=5,patterns,min=minlower,max=maxupper,number=0,samesize,picture='*.#',hlabel='years after shock',header=''+ylabel(i)) 3
Thanks Tom. now get some nice pink! upper lower bounds. The other question was, please, how to get only one graph per line? Following the rats manual, I have tried vfields and hfields option but seem to get an error. Thanks. oz
What does "one graph per line" mean? Six separate graphs instead of 3 x 2 on a page? Just get rid of the SPGRAPH's.
