VEC to VAR
lizhengeconomic
VEC to VAR
Unread post by lizhengeconomic »
Dear all. I have estimated vecm by using ect, I want to get the VAR coefficient. Is there any code to do it ? thanks very much!
Re: VEC to VAR
disp %modelsubstect(ectmodel)
will show you the substituted out model. I'm not sure what you want to do with that---those are reduced form coefficients, so they won't be all that interesting compared with the structural coefficients.
lizhengeconomic
Re: VEC to VAR
TomDoan wrote:disp %modelsubstect(ectmodel)
TomDoan, thanks very much!I want to do a global VAR, first estimate a VECMX model ,then convert VECMX to VARX, finally combine many VARX into a global VAR model.
