VAR Forecast with Exogenous Variable
Jules89
Unread post by Jules89 »
I have estimated a VAR with an exogenous variable. For example with the haversample data:
open data haversample.rat
cal(q) 1959
data(format=rats) 1959:1 2006:4 ftb3 gdph ih cbhm
set loggdp = log(gdph)
set loginv = log(ih)
set logc   = log(cbhm)
compute lags=4
system(model=var)
   variables loggdp loginv logc
   lags 1 to lags
   det constant ftb3{1 to lags}
estimate(noprint,ols,sigma)
Now I want to use the forecast instruction to do out of sample forecasts. In the instruction manual it is written:
"Exogenous variables require some care, as you need values for them throughout the forecast period. If a variable is not the dependent variable of one of the equations, FORECAST takes its values over the forecast horizon from its data series. If you are forecasting out-of-sample, you have two basic ways to handle exogenous variables:
Close the model by adding to it equations or formulas, such as univariate autoregressions, that forecast the exogenous variables.
Set up time paths for the variables (prior to forecasting) with SET or DATA or some other instruction that will directly provide the values.
I don't understand what is meant by "Close the model by adding to it equations or formulas, such as univariate autoregressions, that forecast the exogenous variables."
How would I use the instruction to do the forecasts? Is there anything special to it or is it just:
forecast(model=var, start=%regend(), steps=10, results=forecasts)
Thank you
Best Jules
Re: VAR Forecast with Exogenous Variable
That would work if you want to forecast based upon observed values for the exogenous variable. If you don't have those over the forecast period, then you have to forecast them somehow. Closing the model means exactly that---you have four variables, you need four equations, one of which does ftb3 depending just upon its own lags.
Jules89
Thanks for your reply,
does that mean I have to estimate something like
compute lags=4
system(model=var)
   lags 1 to lags
linreg(define=ftbeq) ftb3
# ftb3{1 to lags}
group varmodel  var ftbeq
How would I implemt that if I don't want to estimate a full system like:
compute lags=4
system(model=var)
   variables loggdp loginv logc ftb
   lags 1 to lags
Thank you in advance
Jules
In your first, do
forecast(model=var+ftbeq, start=%regend(), steps=10, results=forecasts)
Jules89
Sorry the group instruction was wrong. Here it is
cal(q) 1959
compute lags=4
system(model=var)
   lags 1 to lags
# ftb3{1 to lags}
forecast(model=var+ftbeq, from=%regend(), steps=10, results=forecasts)
