Quantile unit root test
Salnusair
Unread post by Salnusair »
I was wondering if there are codes for the Quantile unit root test by Koenker and Xiao (2004). Basically, the test is an extension to the standard ADF unit root test. The tricky part (at lease for me) is simulating the t-values and their p-values. Any help is highly appreciated.
Sal
quantile unit root-koenker and xiao.pdf
(218.03 KiB) Downloaded 902 times
Re: Qunatile unit root test
If you can do the test, can't you relatively easily do the simulations of it?
