Plot of Option Delta over Time to Maturity
alexecon
Unread post by alexecon »
I'm trying to do the above but can't figure out how.
I have had success plotting delta, theta and gamma against the underlying asset price, as in the following program:
smpl 30 70
* calculate BSM price
@BSOPTION(price=49,strike=50,rate=0.05,sigma=0.2,expire=0.3846) bsm
dis "BSM price is" bsm
* calculate and plot BSM prices for a range of asset prices
compute strike=50
compute rate=0.05
compute sigma=0.2
compute cashflow=0
compute expire=0.3846
set s = t
clear d11
clear d22
clear value
* plot of call option premium against asset price
do i=30,70
   compute d11(i)=(log(s(i)/strike)+expire*(rate-cashflow+.5*sigma**2))/(sigma*sqrt(expire))
   compute d22(i)=d11(i)-sigma*sqrt(expire)
   compute value(i)=s(i)*exp(-cashflow*expire)*%cdf(d11(i))-strike*exp(-rate*expire)*%cdf(d22(i))
graph(style=line,header="Call option premium and asset price (in $)",vlabel="Call option premium",hlabel="Asset price") $
 1
# value
* calculate and plot delta against asset prices
clear calldelta
clear putdelta
do i=30,70
   compute calldelta(i)=%cdf(d11(i))
   compute putdelta(i)=%cdf(d11(i))-1
graph(height=%cm(15),width=%cm(12),style=line,header="Call option delta and asset price",vlabel="Call option delta",hlabel="Asset price") $
 1
# calldelta
graph(height=%cm(15),width=%cm(12),style=line,header="Put option delta and asset price",vlabel="Put option delta",hlabel="Asset price") $
 1
# putdelta
* calculate and plot thetas for puts and calls against asset prices
clear calltheta
clear puttheta
do i=30,70
   compute calltheta(i)=-(49*%density(d11(i))*sigma)/(2*sqrt(expire))-(rate*strike*exp(-rate*expire))*%cdf(d22(i))
   compute puttheta(i)=-(49*%density(d11(i))*sigma)/(2*sqrt(expire))+(rate*strike*exp(-rate*expire))*%cdf(-d22(i))
graph(style=line,key=attached,klabel=||"Call","Put"||,header="Thetas and asset price",vlabel="Option Thetas",hlabel="Asset price") $
 2
# calltheta
# puttheta
* calculate and plot gamma for puts and calls against asset prices
clear callputgamma
do i=30,70
   compute callputgamma(i)=(%density(d11(i)))/(49*sigma*sqrt(expire))
graph(style=line,header="Gamma (for puts and calls) and asset price",vlabel="Option Gammma",hlabel="Asset price") $
 1
# callputgamma
Would you be able to resolve this for me? Thank you in advance.
Re: Plot of Option Delta over Time to Maturity
Maybe I'm not understanding what you want, but wouldn't that just be a SCATTER instruction?
alexecon
You're right, I didn't explain well what I need. Before plotting deltas over time, I need to generate them first, e.g. with something like this:
do i = 1,100
compute delta(i)=%cdf((log(price/strike)+expire(i)*(rate-cashflow+.5*sigma**2))/(sigma*sqrt(expire(i))))
The problem with the above is that it loops over integers, whereas I would like it to loop over 0.01, 0.02, ..., 0.1, 0.11, ..., 1.0. For a given price, strike, rate, sigma and cashflow, delta changes with expire. Once I get these 100 values then I can plot them. Thank you for your help.
You might want to look at the portfolio.rpf example, which solves a portfolio problem over a controlled range and does a scatter gram of the solutions.
alexecon
Thank you for all the input. The following shows how to plot option greek parameters against asset prices, maturity, etc. in RATS. The examples correspond to those in the chapter on the Greeks from Hull's Options, Futures and Other Derivatives.
This sets the input values for the non-dividend-paying option:
smpl 30 70
compute strike=50
compute rate=0.05
compute sigma=0.2
compute cashflow=0
* expiry is 20/52 (weeks)
This plots the call option premium against the asset price:
set s = t
clear d11
clear d22
clear value
do i=30,70
graph(style=line,header="Call option premium and asset price (in $)",vlabel="Call option premium",hlabel="Asset price", $
width=%cm(15),height=%cm(10)) $
1
# value
This calculates and plots call and put deltas against asset prices:
clear calldelta
clear putdelta
do i=30,70
 1
# calldelta
 1
# putdelta
This calculates and plots (annual) thetas for puts and calls against asset prices:
clear calltheta
clear puttheta
do i=30,70
graph(style=line,key=attached,klabel=||"Call","Put"||,header="Thetas and asset price",vlabel="Option Thetas",hlabel="Asset price", $
2
# calltheta
# puttheta
This calculates and plots gamma for puts and calls against asset prices:
clear callputgamma
do i=30,70
graph(style=line,header="Gamma (for puts and calls) and asset price",vlabel="Option Gammma",hlabel="Asset price",width=%cm(15),height=%cm(10)) $
 1
# callputgamma
This plots delta against the option's time to maturity for four options (deeply in the money, in the money, at the money and out of the money):
smpl 1 20
clear delta1
clear delta2
clear delta3
clear delta4
do i= 1,20
compute delta1(i)=%cdf((log(55.0/50.0)+((i)/52.0)*(0.05+.5*0.2**2))/(0.2*sqrt((i)/52.0)))
compute delta2(i)=%cdf((log(51.0/50.0)+((i)/52.0)*(0.05+.5*0.2**2))/(0.2*sqrt((i)/52.0)))
compute delta3(i)=%cdf((log(50.0/50.0)+((i)/52.0)*(0.05+.5*0.2**2))/(0.2*sqrt((i)/52.0)))
compute delta4(i)=%cdf((log(48.0/50.0)+((i)/52.0)*(0.05+.5*0.2**2))/(0.2*sqrt((i)/52.0)))
set time = t
graph(style=line,header="Delta and Time",subheader= $
"In-the-money, At-the-money and Out-of-the-money Options",$
hlabel="Time",vlabel="Delta",width=%cm(15),height=%cm(10), $
key=attached,klabel=||"Price = 55 ","Price = 52", $
"Price = 50","Price = 48"||) 4
# delta1
# delta2
# delta3
# delta4
Thank you for your contribution. What's the significance of the 30 to 70 range used (in SMPL's and in DO loops)?
alexecon
TomDoan wrote:Thank you for your contribution. What's the significance of the 30 to 70 range used (in SMPL's and in DO loops)?
This sets the range of asset prices for which the deltas and other greeks are calculated. The horizontal axis in the relevant graphs (i.e. plots of a greek against asset price) uses this range.
