Out-of-sample mean forecasts from VARMA-MGARCH-M
hasanov
Unread post by hasanov »
I am trying to forecast the mean variables from VARMA-MGARCH-M model. Window I am using is the recursive window. I would like to store one-step ahead out-of-sample mean forecasts in “rv1” and “rv2” objects. Could you please guide me on this issue? The way I have done the code does not work.
OPEN DATA "Data.txt"
CALENDAR(M) 1975:1
DATA(FORMAT=PRN,ORG=COLUMNS) 1975:01 2017:12 iip cpi
set riip = 1200.0*(log(iip)-log(iip{1}))
set rcpi = 1200.0*(log(cpi)-log(cpi{1}))
source mvgarchfore.src
dec series rv1
dec series rv2
clear rv1 rv2
dec vect[series] sqrth(2)
dec vect[series] eps(2)
dec symm[series] hhs(2,2)
clear(zeros) hhs
do regend = 2009:12, 2017:12, 1
equation iip_eq riip
# constant sqrth(1) sqrth(2) riip{1} rcpi{1} eps(1){1} eps(2){1}
equation cpi_eq rcpi
group varmah iip_eq cpi_eq
clear(zeros) sqrth eps
smpl 1975:01 regend riip
smpl 1975:01 regend rcpi
do iters=1,3
   estimate(model=varmah,resids=resids)
   set eps(1) %regstart() * = resids(1)
   set eps(2) %regstart() * = resids(2)
end do iters
compute cv0=%sigma
garch(model=varmah, mv=bekk, robust, distrib=norm, rvectors=rv, hmatrices=hh, mvhseries=hhs, pmethod=simplex, presample=cv0,$
    uadjust=%pt(eps,t,rv(t)),hadjust=%(sqrth(1)=sqrt(hhs(1,1)), sqrth(2)=sqrt(hhs(2,2)), piters=15,cvcrit=0.0001, iters=2000)) 1975:01 regend riip rcpi
@MVGarchFore(MV=BEKK, steps=1) hh rv
do i=1,1
compute rv1(regend+i) = rv(regend+i)(1)
compute rv2(regend+i) = rv(regend+i)(2)
display regend
end do regend
print / rv1 rv2
Data.txt
Data file
(7.58 KiB) Downloaded 973 times
Re: Out-of-sample mean forecasts from VARMA-MGARCH-M
There's no closed form forecast for the out-of-sample forecast of that model. There is if the mean is linear in the variance, but not if it's linear in the square root. (The expected value of the square root of h is not the square root of the expected value of h).
hasanov
Thanks Tom for your clarification !
How to generate mean forecast if I remove in-mean (i.e., from VARMA-MGARCH model) ?
Could you correct the following code:
dec series rv1
dec series rv2
clear rv1 rv2
clear(zeros) hhs
equation eq1
# constant var1{1} var2{1} eps(1){1} eps(2){1}
equation eq2
group varmah eq1 eq2
clear(zeros) eps
smpl 1975:01 regend var1
smpl 1975:01 regend var2
do iters=1,3
end do iters
compute cv0=%sigma
    uadjust=%pt(eps,t,rv(t)), piters=15,cvcrit=0.0001, iters=2000)) 1975:01 regend var1 var2
do i=1,1
display regend
end do regend
print / rv1 rv2
What exactly is it that you're (in the end) trying to do? You've now changed your model twice to try to fit it into a simpler framework. Is there a reason that simulation methods won't do what you want?
