Print coeffs of a VAR model
lali62
Unread post by lali62 »
How do I see the coeffs of a varmodel and its dimensions
Lets say I have have a varmodel with 6 variables and 12 lags, I expect the coeff matrix to be of dimension 72 * 6
I then pass another coeff matrix into the varmodel as
I want to again print and see the coeffs of the varmodel as I pass this modified varmodel into irf and want to make sure it shows betadraw
impulse(noprint,model=varmodel,results=impulses,steps=nstep)
Re: Print coeffs of a VAR model
The companion to %modelsetcoeffs is %modelgetcoeffs.
disp %modelgetcoeffs(varmodel)
will give you what you want.
