Error message for Montevar
msrahman
Unread post by msrahman »
I am receiving following message when I run the attached program. Any advice?
Sincerely,
Sajjadur.
## MAT2. Matrices with Dimensions 31 x 6 and 13 x 6 Involved in + Operation
The Error Occurred At Location 634, Line 66 of MONTEVAR
/Users/RahmanMd/Documents/Mac_new/monetary_fiscal_policy/montevar.src Line 99
exp_one.rpf
(2.12 KiB) Downloaded 830 times
Re: Error message for Montevar
@MONTEVAR assumes that the most recently completed estimation instruction is the ESTIMATE for the VAR. You are inserting the estimation of the structural VAR. Move it up after the ESTIMATE and it will work fine.
msrahman
Does it mean that @MONTEVAR does not work with Structural VAR?
Sincerely,
Sajjadur.
Correct. You can only use it with a just-identified model. That's why you have to do some form of MCMC to analyze an SVAR.
