Code for Unrestricted BEKK
curiousresearcher
Unread post by curiousresearcher »
Please share the code for unrestricted BEKK as used in this research paper - https://www.sciencedirect.com/science/a ... 2318308237
Re: Code for Unrestricted BEKK
That paper is behind a paywall, but what is an "unrestricted" BEKK? A standard BEKK (MV=BEKK on the GARCH instruction) is unrestricted; TBEKK and DBEKK are restricted forms.
You might want to read the article from the April 2019 newsletter:
Spillover/Causality-in-Variance Tests
In BEKK models the "spillover" is sometimes just an artifact of how BEKK handles the covariances.
curiousresearcher
Hello Tom,
When i am using the normal BEKK command as suggested, the results are showing no spillover at all between the cryptocurrencies.
But this paper is showing bi-directional spillover among the
The data i am using matches with that of the paper. So it seems the problem relates to the code used
I am also attaching the data for bitcoin and ether for your reference here used in the paper.
Will appreciate if i can get the code which gets me the result in this paper.
Thanks a lot in advance
* code used is
garch(p=1, q=1,mv=bekk,robusterrors,stdresids=rstd) / BTC ETH
data for estima forum.xlsx
(54.41 KiB) Downloaded 795 times
Do you actually have the data that they used, or do you have what you think is the same data (based upon their description)?
curiousresearcher
I have the data they have used as i have matched by descriptive statistics - mean/median/no of obs. etc with their summary stats in the paper.
