How Can I Set Covariance Graphs For VAR(1)-BEKK-GARCH(1,1)
Scout_Boy
Unread post by Scout_Boy »
I am estimating the VAR(1)-BEKK-GARCH(1,1) model and would like to ask how can I set the graph code for the covariance for i.e. hhs(1,2)?
Thank you with best regards,
Re: How Can I Set Covariance Graphs For VAR(1)-BEKK-GARCH(1,
See
https://estima.com/docs/RATS%2010%20Use ... f#page=328
The example graphs the correlations (rather than covariances); for covariances instead, you would do the same thing without the %CVTOCORR(..) function. For instance,
set jpnfra = hh(t)(1,2)
is the covariance between JPN and FRA.
