any parameter instability for nonlinear least square (nlls)?
mjchang36
Unread post by mjchang36 »
Hello everyone:
I wolud be very pleased if you inform me whether there is any written code for testing parameter stability for nonlinear least square model in RATS or suggest me any applicable test for that. Thanks with regards.
mjchang36
Re: any parameter instability for nonlinear least square (nl
If you have a known break point, you can just do a sample split Chow test. If you have an unknown break point, you can use @FLUX or @APGRADIENT to look for a general break. Those are both designed to take the scores directly off an instruction estimating by maximum likelihood, so you have to do an extra step with NLLS of multiplying the derivatives by the residuals, such as
nlls(frml=nlconst,derives=scores)
do i=1,%nreg
   set scores(i) = scores(i)*%resids
@flux
# scores
@apgradienttest
# scores
mjchang36
thank you.
