Recursive Prediction Intervals (small sample)
ac_1
Unread post by ac_1 »
I would like to calculate prediction intervals from recursive forecasts (small sample), is this the correct method?
clear yhat_r_model2
clear dfs
clear dfs1
do regend = ibegin, iend
linreg(define=eqmodel2,print) y istart regend
# constant x1{1} x2{1} x3{1}
uforecast(equation=eqmodel2,from=regend+1,steps=1,stderrs=stderrs) yhat_r_model2
set dfs regend iend = %ndf
end do regend
set dfs1 ibegin+1 iend+1 = dfs{1}
prin / y dfs dfs1 yhat_r_model2 stderrs
set lower95 ibegin+1 iend+1 = yhat_r_model2+%invtcdf(.025,dfs1)*stderrs
set upper95 ibegin+1 iend+1 = yhat_r_model2+%invtcdf(.975,dfs1)*stderrs
prin / y yhat_r_model2 lower95 upper95
or are the stderrs via ?
prj(stderrs=stderrs) yhat_r_model2 regend+1 regend+1
many thanks,
Amarjit
Re: Recursive Prediction Intervals (small sample)
Don't they give the same results? Without any dynamics in the model, the standard errors of forecast are computed the same way for any number of steps, just using the static projection formula.
ac_1
Thanks - as in https://estima.com/ratshelp/index.html? ... ction.html Options -> STDERRS -> ERRORS -> Technical Information.
